Quantcast Oil leaking / Coolant weeping
This is a discussion on Oil leaking / Coolant weeping within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; I have a 2003 CRF450 and while I was riding i noticed quite a bit of what appeared to be ...
Old 11-25-2008, 08:55 PM
lbzrider's Avatar
Last Online: 11-26-2008 12:35 AM
Default Oil leaking / Coolant weeping
I have a 2003 CRF450 and while I was riding i noticed quite a bit of what appeared to be oil coming out of what looks like a drainage hole in the right side of the motor. What causes this? Is it normal? And if not, what corrective action should I take??
In addition I have some coolant that weeps from the water pump sometimes, a friend of mine told me that his CRF did the same thing and not to worry about it but????
Thanks for any and all insight.
--Travis
Old 11-25-2008, 11:47 PM
JS89's Avatar
Last Online: Today 12:52 PM
You might of put a little to much oil in it and spit it out.
The the coolent leaks are you sitting in one spot, Most fourstokes will do it when sitting and getting no air.
The Following User Says Thank You to JS89 For This Useful Post:
lbzrider (11-26-2008)
Old 11-26-2008, 12:35 AM
lbzrider's Avatar
Thanks alot! I will check that....I need to change the oil anyways and i will make sure that there is the right amount in the engine. I bought it off a friend and he had just redone the top end so he may have just put too much in.
And about the coolant, yes it is when i'm stopped not when riding. So that sounds like it is the culprit!!
Thanks alot for your help, if anyone else has any idea about the oil leak i'd like to hear it, but i will repost to see if checking the oil lever fixes it.
Thanks again!!
Old 11-26-2008, 02:24 AM
Duran676's Avatar
Last Online: 12-13-2008 07:59 AM
I was gonna say the same thing about the oil aswell, im no expert but thats the first thing that came to my mind.
Old 11-26-2008, 02:33 AM
JDR215's Avatar
Last Online: Today 02:56 AM
are u talking about the hole next to ur water pump? if so then more than likely ur impeller shaft is worn and needs replacing, with new seals also.
the impeller shaft gets little grooves in it over time, from the seals, and thats when they start letting oil and water out.
Old 11-26-2008, 02:43 AM
pjg351's Avatar
Tie me Kangaroo down sport
Last Online: Today 09:31 AM
JD is right, sounds like it's leaking out the weep hole for the water pump!
Old 11-28-2008, 03:41 AM
I've been RM-Zedded
Last Online: Yesterday 07:11 PM
I had the same problem on my 2003 CRF450, and it required a new shaft to fix it.
Their is also a new impeller that I believe they came out with in 2005 or 2006 that has a hole in it that will help the seals seal better, so you don't have the problem again.
The newer version will bolt right onto the shaft as well. I bought the new seals (inner and outter) new shaft, and new impeller and it wasn't leaking when I sold it a few years later. Easy job to do as well.
Tags
leaking, normal, oil, weeping
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: Oil leaking / Coolant weeping
leaking coolant on my 2002 cr250 but not out of the rad blake_vail 2-Stroke Motorcycles - General Discussion 9 06-19-2008 06:22 PM
03 CRF450r leaking coolant? chriscrash 4-Stroke Motorcycles - Honda 1 05-13-2007 01:28 PM
2000 CR80 COOLANT LEAKING FROM OVERFLOW BDNWTKFG 2-Stroke Motorcycles - Honda 16 01-19-2007 11:59 PM
02 CRF450 leaking coolant? CAD 4-Stroke Motorcycles - Honda 10 10-30-2006 09:34 PM
leaking coolant 04blue450 ATV/UTV - Yamaha 8 03-07-2005 09:55 AM
vB.Sponsors
Page generated in 0.16362 seconds with 12 queries
