Leaky Cooling System
This is a discussion on Leaky Cooling System within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; Hey everyone, I have a 2003 CRF450 and found that I have a major leaking issue with my cooling system. ...
Old 02-01-2009, 01:31 AM
lbzrider's Avatar
Last Online: 09-13-2009 02:03 PM
Usflag Leaky Cooling System
Hey everyone,
I have a 2003 CRF450 and found that I have a major leaking issue with my cooling system. I am experiencing leakage from where the radiator hose goes into the motor. (see attached picture) There is an 8mm bolt going into the motor case from between the motor and the silver piece. I didn't realize it was leaking until there was steam shooting out of the vent tube....not good....and there was little-no coolant left in my bike. I checked the little gasket in there and it looks good, is there anything else that could be causing this leak besides a faulty O ring??
Travis
Old 02-01-2009, 01:52 AM
I've been RM-Zedded
Last Online: Today 01:39 PM
The only thing I can think is that the pipe that goes into it got a bit bent (since it has only one screw to hold it on) so it doesn't sit at the correct angle. That or the pipe its self is cracked maybe. Could also be the hose that hooks onto it. Could even be your radiator.
My suggestion is to fill it with water, warm it up on the stand and see exactly where the leak comes from.
Sometimes those leaks can be a hair line crack, that doesn't manifest its self until the motor/coolant is warm.
Old 02-01-2009, 11:27 AM
lbzrider's Avatar
Thanks, I will further investigate this issue. I had a buddy tell me that it could be a hairline crack as well. It leaks when the bike isn't even on now...Im gunna tear it apart again and see what I can find out. And i'll repost on what I Uncover. Thanks again...if there is anything else you can think it may be, let me know.
Old 02-02-2009, 03:10 PM
I've been RM-Zedded
I don't have anything else to add other than good luck! Let us know what happens/what you find.
Old 02-02-2009, 10:23 PM
lbzrider's Avatar
Default Problem solved...
It turned out to be nothing but a leaky gasket, I got a new one that fit alot better and the problem is solved...I am still having the leaking from the telltale hole so I will probably be replacing my water pump to solve this problem. Thanks for the help!!
-- Travis
Old 02-03-2009, 01:54 PM
I've been RM-Zedded
Good to hear. Just so you know the water pump is an easy job. Just make sure you have all the gaskets and you should be fine. I suggest replacing both inner and outter oil gaskets (they go around the impeller shaft), a new shaft, and a 2006 water pump impeller (optional, but helps fix the problem).
Old 02-03-2009, 02:13 PM
lbzrider's Avatar
Default Sweet, Thanks...
Yea I have read some of the other threads and that seems like the way to go...I have an 06 piston in my bike too...and the added compression made a big difference. I also have to check the valve spacing and since i'm new to the 4 strokes i'm kinda intimidated by it all, but i'm sure following the manual will get me through it...
Thanks again
Old 02-03-2009, 02:27 PM
I've been RM-Zedded
Yep, you'll do fine!
Tags
coolant, leak, leaky
Similar Threads for: Leaky Cooling System
crf 250x cooling fan 89 cr250r 4-Stroke Motorcycles - Honda 3 12-04-2007 03:10 PM
raptor cooling fan? chris99 ATV/UTV - Yamaha 15 06-23-2005 11:10 PM
Cooling system ??? reborn_450 General Discussion 3 03-28-2004 10:09 PM
cooling Racer#857 General Discussion 28 03-23-2004 02:41 PM
Cooling fan on a YZF250? yami250fgal393 4-Stroke Motorcycles - Yamaha 6 01-28-2004 06:48 PM
