Hiccup on load when hot?
This is a discussion on Hiccup on load when hot? within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; Hey all, I have a honda XLX250R , Its had a rebuild and was running great. I tuned it and ...
Old 05-16-2005, 06:42 AM
Last Online: 08-21-2005 05:40 AM
Default Hiccup on load when hot?
Hey all,
I have a honda XLX250R , Its had a rebuild and was running great. I tuned it and it was running great, starts first kick when cold with full choke and runs great fro about the first 30 mins.
Then when it gets hot at about 5,000rpm+ with id say 60%+ throttle it hicupps and struggles to make power or build revs.
Im wondering do you think its running rich or lean? Ive just replaced the plug so not that...
The way I tuned it was:
Started the bike, let it get hot, then wound the fuel screw out. then slowly wound it in until it raised to a peak rpm, then backed it out 1/4 turn..
If anyone could point me into the right direction id really appreciate it
cheers
Old 05-16-2005, 12:34 PM
I've been RM-Zedded
Last Online: Yesterday 07:03 PM
Default Re: Hiccup on load when hot?
Sounds like you are maybe too rich up on the top. I'd start by lowering the clip on the needle (raising the needle) and see if that helps. If it does, you may need a fatter main.
Old 04-09-2008, 08:12 AM
Last Online: 06-26-2009 03:28 PM
um i thought you drop the needle by raising the clip twards the top of the needle to lean out the mixture through out the throttle range. Theres a good chance that the powerrvalves are just not doing there job and opening up as thoght the should. this i have personally seen on alot of mx bikes. the popwervavles just might not be doing there job, wheather or not there cloged up with sludge or if there just malfunctioned. make sure to check that out. i would check it before playing with dangerously lean conditions to see if the bike stops the sputter.
Rare chance, but it could also be an ignition coil or cdi box, but those are hard to test. go thru the steps and then get back to us.
Old 04-09-2008, 03:00 PM
I've been RM-Zedded
Uhm you are 100% correct
Old 04-09-2008, 04:06 PM
Big Maico 393's Avatar
Super Moderator
Last Online: 11-05-2009 05:15 PM
Recheck your valves!
Does it seem like it has less compression when hot? valves might be just a little tight & when it gets hot it loses compression & power.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: Hiccup on load when hot?
This is how to load your bike MotoMan Photo & Video 3 11-18-2006 09:16 PM
How Not to load a bike. mxSteve General Discussion 7 03-23-2004 01:56 PM
How to load the bike WILLETTS General Discussion 8 01-13-2004 08:14 PM
How to load a bike Racer#857 General Discussion 15 11-09-2003 10:18 PM
get a load of this :) TTR125L02 General Discussion 14 09-04-2003 11:36 PM
vB.Sponsors
