Old 05-02-2019, 10:24 AM
Last Online: Today 09:29 AM
Getting good photos is a real pain, trying to work around the front tire and such but I did my best.
Old 05-02-2019, 06:16 PM
Big Maico 393's Avatar
Super Moderator
Last Online: 02-25-2020 09:05 PM
Chase,
Is that bolt steel or aluminum ?
Have you tried heating up the bolt housing, then touching the bolt with a piece of ice?
Sometimes it will break the bond between the case & the bolt.
But it looks like you'll have to have a handle welded on to it to fix it.
Old 05-03-2019, 09:19 AM
Originally Posted by Big Maico 393 View Post
Chase,
I did heat up the little pipe/spigot the bolt threads into with a propane torch and didn't have any luck. I'm a bit nervous about trying the oxy/acetylene torch on it...
I'd like to try grinding down the flange area of the bolt a little more, one to square it up more and two to try and get the crush washer out. That might release enough tension to get it out. Next step is a welder, trying to find a 110v welder to borrow because my 220 plug isn't in a convenient spot.
Old 05-03-2019, 11:05 PM
bjunior's Avatar
novice
Last Online: Today 03:50 PM
Default Electric Discharge Machine
Electric discharge machining would work on that if ones in your neck of the woods.
Old 05-06-2019, 09:24 AM
I'm sure I could find someone but I'll get it eventually.
Old 05-06-2019, 01:28 PM
Last Online: Yesterday 10:08 AM
It looks like that's a tough location. Now that you have a flat cut in it you might be able to use one of those hammer impact drivers. Back in the day it was a lifesaver on case screws that were phillips. Doubt you have great access to get at it there.
https://www.sears.com/craftsman-impa...EaAtmMEALw_wcB
Old 05-06-2019, 01:46 PM
If I dropped the front end there would be all kinds of access, just don't want to if I can help it.
Old 05-12-2019, 09:33 AM
wFo250's Avatar
will fall over
Last Online: 02-22-2020 08:40 AM
One more vote for the flathead impact
Old 05-16-2019, 02:08 PM
Last Online: 09-09-2019 07:11 PM
Bring that thing by, we'll have it out in 5 minutes.
I see no issue with getting that sleeve dark red with a torch. You're going to drain the oil after you get it out anyway, so a little burnt oil won't be an issue. Find an old socket that doesn't quite fit over what's left of that bolt head and hammer it on before you start. Put some quick heat to the sleeve and it should break free.
Old 05-17-2019, 12:19 PM
I may get in touch with you next week, been focused on my boat but I'm tired of working on that piece of crap!
« 1985 Honda XR350R | - »
Similar Threads for: Help me, I have an illness
Back online, out since December due to illness Florida YZ426 Member Introductions 14 07-23-2010 02:12 PM
Shae Bently illness story Florida 393 General Discussion 0 03-17-2008 10:17 AM
