Old 05-15-2006, 11:05 PM
tHeKiNgMaN's Avatar
Last Online: 01-03-2008 06:17 AM
Default Electric start for Crf450r?
I've been searching the WWW and have had little luck. Also little luck with a light kit. ie:head light/tail light Anybody try to switch the 450x components? Will it work with '03 frame? Will i have to spend mucho denero$$$???? I'd hate to have to buy a new bike just to get lights and stuff. Law in the land now it's required to have lights so i figured check the electric start as well. Anyway whatever info you guys have will be great. Thanks .
Old 05-15-2006, 11:11 PM
crfjedi393's Avatar
Last Online: 03-31-2015 10:33 PM
Default Re: Electric start for Crf450r?
The lights and kill swicth are pretty much just cosmetics. I see no reason they wouldn't work on an '03 but I'm not speaking from experience. Your local Honda shop should be able to set you up. I'll make a note to speak with my dealer tomorrow.
Old 05-16-2006, 12:10 PM
VET393's Avatar
Last Online: 09-17-2013 12:07 PM
Why not look here...
https://www.bajadesigns.com/NET/main....aspx?content=
I have seen this stuff on ebay before
Old 05-16-2006, 07:41 PM
tHeKiNgMaN's Avatar
Ya I'v been looking there it says something about sending my stator in for a rewind before it will work and it all seems a little pricy. I'm hopping to find something much cheeper.
Old 05-16-2006, 11:04 PM
chabat's Avatar
Last Online: 03-24-2016 09:08 PM
Most stock wound lighting stator/coils don't have a lot of oomph. Baja designs supposedly do a good job with lights. There are lights and there are LIGHTS!!! I think if you plan on being a night rider, your safety is worth better visibility. JMO.
I have a buggy with stock lighting system, the lights are pretty weak. I can make it back to camp with them, but they don't inspire confidence at night.
Old 05-16-2006, 11:17 PM
tHeKiNgMaN's Avatar
I don't need to ride at night the law says i need a head/tail light for trail riding.
Old 05-16-2006, 11:48 PM
char393's Avatar
cha cha
Don't know if he'll have what you need, but worth a look anyway:
http://www.rickystator.com/
Old 05-17-2006, 08:12 PM
tHeKiNgMaN's Avatar
Seems like mostly quad stuff. No stator for 450
Old 05-17-2006, 09:54 PM
char393's Avatar
cha cha
Might want to give him a call and tell him what you're needing. He may be able to point you in the right direction?
Old 07-22-2006, 02:32 PM
Stryke's Avatar
Last Online: 09-08-2007 01:59 AM
www.steahlyoffroad.com
All u need is to pick between one of the headlight designs DHH is my fav. Then If u want more wattage u can buy bigger bulbs. If u want a tail lighht they have those too.
After that u need to buy a lighting coil for your bike. There like $180. All u need to do is remove the flywheel with a flywheel remover tool. Then take out the stock coil and place in the aftermarket coil. They will have a specific coil for your 2003 crf450r.
Then u need to buy a wire harness so u can wire it up. $16
Then you need to buy the switch they have so u can turn the lights on and off. $23
And lastly you will need to buy a voltage regulator so that you headlight doesnt burn out. $15
Rhe online store go to part number L-1495 Its the coil for the all crf450s.
Total it will cost around $330
Old 07-22-2006, 03:20 PM
Silver_Fox's Avatar
Last Online: 02-22-2017 10:36 AM
The last time I checked with the local conservation officer I was told you did not need the actual lights BUT, your bike does have to have a lighting coil. Just hang some wires out from beneath your tank and tell them its from your coil . I'll check and see if they are actually enforcing lights. You ride the Cadomin area right?
Old 07-22-2006, 06:32 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Today 02:22 PM
Here's where you need to look!
http://trailtech.net/dc_conversion.htm
Then looks here
http://trailtech.net/sufficient%20dc%20power.pdf
Old 07-24-2006, 04:13 PM
tHeKiNgMaN's Avatar
I have been around cadomin like bruel lake not latly though. last feb at the bike show is when i first herd of it and i know my bud got a ticket at mcclain creek west of calgary.
Old 07-24-2006, 05:14 PM
Stryke's Avatar
I will be at mclean creek campground for 2 weeks maybe more in a little while. I dont know when im leaving though. Most likely saturday or sumthin. Mclean is awsome.
Old 07-24-2006, 07:39 PM
tHeKiNgMaN's Avatar
yeah its real fun, long drive for me though. I'll be at wild rose motox track in calgary next week then wypress in sept.
Old 08-01-2006, 08:56 AM
Last Online: 05-19-2014 05:10 PM
There's no getting around the fact that it takes electricity to make lights work and the stock CRF doesn't make much of it. If you don't need to ride at night just get a cheep internal lighing coil/stator. If you actually want to be able to see well in the dark get a 200wt e-line/bajadesigns stator. Most all the major plastic companies and bajadesigns make head and tail lights. For the tail light I like the bajaD LED unit.
Old 08-08-2009, 08:46 AM
bplm26's Avatar
Last Online: 08-08-2009 09:01 AM
Default has it been done ??????????
Ok I found this thread by searching electric start for a 2005 CRF450R. You talk about Lights and Stators But will a Starter Bolt on? Is there a Mounting Place. If Cost wasnt an issue could it be done? I do not Want a CRF450X because the gearing and Steering Head angle is Diferent. Not to mention i have 2 tons of $$$$ in my bike and like it. I Just cant start it hot when i am Tired, i only Weigh 150lbs Soaking wet with Gear. Oh yea it has a High Compression Athena 490 kit on it............
Old 12-01-2009, 10:37 PM
Last Online: 12-01-2009 10:37 PM
I agree.
Similar Threads for: Electric start for Crf450r?
Electric dirt bike. Silver_Fox General Discussion 6 03-17-2008 08:16 PM
electric start for kx500 gto7419 2-Stroke Dirt Bikes - Kawasaki 2 04-25-2005 04:36 AM
electric motocross HiG4s General Discussion 41 12-18-2004 04:57 PM
Electric Shock pragmatic393 General Discussion 16 02-10-2004 03:09 PM
'03 TTR125LE Electric Start $2200 DFW,TX DPW Classified Ads 0 10-16-2003 01:10 PM
