Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums > 4-Stroke Dirt Bike - Honda
CRF250 air filter change
This is a discussion on CRF250 air filter change within the 4-Stroke Dirt Bike - Honda forum, part of the 4-Stroke Dirt Bike Bike Forums category; About to change out the air filter on my CRF and in looking through the shop manual, it says I ...
Old 01-11-2008, 06:44 PM
kjjz28's Avatar
Last Online: 02-16-2013 08:24 AM
Default CRF250 air filter change
About to change out the air filter on my CRF and in looking through the shop manual, it says I need to remove the subframe to replace the air filter...is this true? It looks like if I turn the cage/filter at an angle, it will come out or am I subjecting the filter to possible damage?
I read a previous post about not using "No-Toil" on UNI filters but is it O.K to use it on Twin Air or Moose Filters? What do filters cost these days?
Thanks folks!
Old 01-11-2008, 06:48 PM
crfjedi393's Avatar
Super Moderator
Last Online: Yesterday 10:13 PM
Default Re: CRF250 air filter change
Definitely no need to remove the sub frame.
I can't answer your other questions as I use a K&N.
Old 01-11-2008, 07:04 PM
Dirt Machine
Last Online: 05-16-2013 04:58 PM
I just used a stock filter (I liked them best), and no-toil was fine on it. Can't speak to the twin-air or moose. But I've not heard anything either. I have heard about the twin air problems though.
Old 01-11-2008, 08:35 PM
char393's Avatar
cha cha
Last Online: 05-17-2013 08:54 AM
I run moose filters with No-Toil. I think moose filters run around $20-25, but it's been a while since I've bought any. Recently I bought the pre-oiled No-Toil filters, I think they're right around $10. Not sure how many uses you can get out of one, I think I've cleaned mine three times now.
Old 01-12-2008, 10:45 PM
Dirt Machine
I do enjoy those no-toil pre-oiled filters a bunch. Cleaning isn't bad, but if I can swing it, I like to just buy those instead.
Old 01-13-2008, 04:50 AM
dhighlan's Avatar
Last Online: 12-02-2008 08:00 AM
Are you sure it says you need to remove the sub frame for the air filter or the air box? There is no access anywhere other than the top that doesn't even make sense.
Old 01-13-2008, 07:41 AM
kjjz28's Avatar
I got the filter out without removing the subframe...the diagram in the manual makes it look like you have to remove it to get to the airfilter but it really is to get to the entire airbox.
BTW...went to two dealers yesterday and another motorcycle parts store and none of them had either a Honda filter, No-Toil or Twin Air. One of the dealers did have a Maxima pre-oiled "Ready Filter" that appears to be marketed as a single use filter. I needed one to ride with my son today so I went ahead and bought the filter. Anyone have experience with these? Are they truly single use or can they be cleaned/re-oiled and used again until I can get another filter ordered? Thanks!
Old 01-13-2008, 07:50 AM
dhighlan's Avatar
I use Ready filters and reuse them as well. They can be reused until which time the material starts to degrades. I find it is around 4-6x depending on how delicate you are when washing them out. They are fantastic to just have a spare in the tool box. Not as thick and durable as Uni or Twin Air but I change mine every ride or 2.
Old 01-14-2008, 11:43 AM
joe346CBMX's Avatar
Last Online: 05-28-2010 04:42 PM
I have use stock, twin air and moose on my crf250's with no problems. Moose are the least expensive and durable as any i have used. They are smaller than the stockers too. You can get it preoiled for $1 more. I pay about $15 with my discount. So for a spare to go with the stocker or replacements I buy Moose. Never messed with subframe just twist the cage a little to get it in and out of the subframe.
ABout the K and N, Is it worth the price. ANy noticeable performance gain. thanks, j
Old 01-16-2008, 03:01 PM
mx468's Avatar
Last Online: 01-05-2012 08:10 AM
I use a twin air dual stage filter with the twin air filter cage. It allows more air into your carb and is easier to use than the restrictive stock cage you use in your crf. Notoil oil and cleaner a must.
Heres a link with more info on twinair.
Similar Threads for: CRF250 air filter change
2001 Honda XR250R Oil and Filter Change rubberman52 4-Stroke Dirt Bike - Honda 5 03-13-2009 12:30 AM
kx450f oil filter change mistake Team Green 4-Stroke Dirt Bike - Kawasaki 11 10-14-2006 08:32 PM
crf 250 oil filter change??? nemoto Product Reviews 0 03-28-2004 06:02 PM
Oil Filter Change huffdaddy70 4-Stroke Dirt Bike - Suzuki 8 02-25-2004 06:54 PM
How often do you change your oil filter? MotoMan 4-Stroke Dirt Bike - General Discussion 12 05-21-2003 12:27 PM
