All Things Moto! Web Forums
changing engine oil problems !!!! HELP
This is a discussion on changing engine oil problems !!!! HELP within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; hi guys. ok so heres the thing. i recently bought an 07 crf250r and today was the firts time i ...
Old 10-20-2009, 11:41 AM
Last Online: 10-21-2009 04:44 AM
Moto changing engine oil problems !!!! HELP
hi guys.
ok so heres the thing. i recently bought an 07 crf250r and today was the firts time i changed the engine oil.
so i took it for a short ride first just 10 mins or so to get the bike all warmed.
then i drained the oil and and kicked it over a few times as stated in manual to do, then took off filter cover cleaned it and replaced with a new filter and put it all back together.
whilst i was filling i thought it was starnge that after i put about 700cc of oil in i still couldnt see any oil on the dipstick side. none what so ever it was dry so i got a torch and looked into the casing and no oil inside. went back to the right hand side of the bike looked in and plenty of oil.
now what did i do wrong? why wont the oil move into the left side casing area and show the level of oil on the dip stick ? i moved the bike around and even tride to kick it over just so things moved inside but with out starting it and still no oil in the dip stick side.
so i have just left it and tried to find a solution in the manual but with no luck
please help i really dont want to F@%k it so soon after i got it..
can anyone shed some light as to what i can do to fix this problem
thanks Huge novice here..
Old 10-20-2009, 12:27 PM
fordmugg's Avatar
Last Online: Yesterday 08:55 PM
are there 2 diffrent oils like the 450's
Old 10-20-2009, 12:46 PM
Duran676's Avatar
Last Online: 11-12-2009 11:43 AM
i believe both 250's and 450's hondas have 2 dif kind of oil tranny and engine and need to be filled seperatly... now with that said im not a Honda guy and im sure the reall honda guys will chime in soon with the info you need
Old 10-20-2009, 01:38 PM
MotoMan's Avatar
Floppy
Yep, you need to put oil in the left side (engine side) as well as the clutch side.
Fill it until the oil comes to the top of the sight window, kick the bike over slow to get oil back up thru the motor, then start the bike, after you shut it off you should have the oil close to the middle of the H and L in the window.
Old 10-20-2009, 09:52 PM
Mainjet2001's Avatar
Last Online: Yesterday 01:06 PM
Hey Jenkins……you really in Beijing?
Welcome to ATM.
O.K., I have a 04 and a 07 CRF250X. Both bikes take more oil in the trans and the engine.
The manual says .69 liter (690cc) for the engine but requires 760 cc to fill it to the upper line on the dipstick.
The manual says .67 liter (670cc) for the trans (not disassembled) but required 840cc to fill it to the run out
point of the drain bolt hole (where the oil runs out).
My 04 bike has the same situation as needing more oil, maybe a little difference in quantity but not much.
If you poured 700 cc into your engine, start it up (you have enough oil in it to “not” cause any damage) and let it idle for 2-3 minutes. Don’t raise the idle during this part.
Kill the engine and check the engine oil level with the dipstick and chances are you will need more oil (50-100 cc).
Make sure the bike is level when checking both the trans and engine oil.
Remove the oil check bolt, again with the bike level, and fill the trans with trans oil until it starts to run out the bolt hole. Re-install the bolt with a new crush washer and run it.
One more thing, measure your oil as you pour it in and make a note of the volumes, saves time on the next change
Hope this helps.
Old 10-20-2009, 11:26 PM
hey guys thanks for the tips, yes it all helped i didnt realise that the trans and engine oil was different and there looking in the wrong one doh.
ok one more question, is it ok to use the same oil for both engine and transmission sae 10 w 40. or is the tranny oil my gear specific.
please advise on your preferences..
thanks and yep i really am in beijing, getting into winter now but we do have some good tracks and mountains out here to rip around on..
cheers guys and thanks this ATM site is a life saver..
ciao
Old 10-21-2009, 09:52 AM
fordmugg's Avatar
they are two diffrent oils ...one is a engine oil and other is trans.....if there is a shop by you then pick up the honda trans fluid and engine oil
Old 10-21-2009, 09:59 AM
MotoMan's Avatar
Floppy
ciao
You can use the same oil, but it can't be "energy conserving". AMSOIL makes a 10W40 you can use in both sides, works out great!!
Old 10-21-2009, 01:59 PM
vr4king's Avatar
Scared Very Scared
Last Online: 11-19-2009 01:47 PM
Also another note the drain pionts for both sides are different the gearbox drain bolt is just below and a little left of the gear shifter and the engine is underneath as per norm
If you havent drained the g/box you could have just poured another 700 odd ccs of oil right on top what was already in there
I use the same oil for both sides but am considering using different oils now
To check the level on the g/box it shoild "weep" out the check hole located on the right side just below and left of the water pump cover
To check the engine side use the dipstick it shoud be about half way between the two marks WITHOUT screwing the dipstick in ie just sitting it in there
Old 11-15-2009, 06:14 PM
neodyman's Avatar
Moving Up
Last Online: 11-17-2009 07:26 PM
Hi, I just got a 08 crf250r and a friend said that these bikes have 3 different oils? gear/crank/head? I know that the 2 gear and crank oils, but I don't have a manual yet and wanted to know about the head? I haven't got the bike yet but I want to change the oil when I get it "probably" Wednesday so I can rip around my track.
Old 11-15-2009, 10:35 PM
You friend is right about 3 different oils only they are engine, trans, and shock oil.
He is wrong on the crank/head part. That oil is the same (engine oil).
I would get a service manual quickly.
Old 11-15-2009, 10:58 PM
neodyman's Avatar
Moving Up
I have been researching all evening about it, I'm used to Yamaha, I have never heard of separate oils?? but it does make sense, I'm going to get a manual next week at Honda, I must of misunderstood my friend, he probably meant that the gear/engine, and i thought that the head was seperate too, but what can I run for the gear box? 40w? I'm going to run good oil in the crank/engine part amsoil.
the bike I bought, "it is being shipped to me this week", has a full FMF system, and was wondering off hand if anyone knows roughly what main jet should be?? I'm going to pull the plug when I get it to see how it is..
Similar Threads for: changing engine oil problems !!!! HELP
Bottom end power delivery - changing gearing vs engine power yzernie General Discussion 0 08-21-2009 06:45 PM
2001 CR 250 Engine problems 212pilot 2-Stroke Motorcycles - Honda 4 02-04-2009 01:04 AM
Engine problems 08/09! pjg351 4-Stroke Motorcycles - KTM 1 11-04-2008 07:07 PM
engine problems magnethead General Discussion 11 02-14-2005 10:34 AM
How To: Daddog Changing Engine Piston Woody_393 DogRiders YFZ450 Tech Pages 1 05-22-2004 04:48 AM
