Old 05-17-2013, 12:41 PM
Last Online: 04-01-2015 08:27 PM
Default 85 XR200r blowin smoke.
My buddy has 2 bikes that need to topends and probably the pistons with rings and all the other stuff to. I've searched and can't seem to find new heads or pistons anywhere. What should he do in order to keep these bikes running and now blow blue smoke like a 2 stroke?
Old 05-17-2013, 02:10 PM
Oddyear. Honda is probably your only source
Old 05-17-2013, 11:13 PM
Can't find parts anywhere, I called a couple of internet company's and they can't help either, local Honda shops are clueless. I don't want to junk the bike because I can't find parts for the engine. Are they're any options for my problem? And no I don't want to buy a new bike if I don't have to!
Old 05-18-2013, 12:45 AM
bike bandit still shows rings and crank parts, valve seals etc. you may have to be more creative. they shared alot with the short stroke 250. I would start checking pin size and height. Try los angeles sleeve company too, they can tell you lots of that, and they may have a piston you can use.
Old 05-18-2013, 05:11 PM
I guess that's the best bet to run the engine is to sleeve it and upgrade in piston size. So all I'd ever have to do is re-sleeve and get new pistons for the rest of the life of the bike.
Old 05-18-2013, 06:10 PM
how long you think this one is going to live? lol, they probably have something you can bore your present cylinder to. have you see the liner on a 4 valve 200?
Old 05-18-2013, 07:29 PM
OLDMXRACER 393's Avatar
Last Online: 12-15-2018 04:16 PM
Are you troubleshooting a 2 valve, or 4 valve engine here Andy? I would think there should be tons of stuff for the 2 valve....
Old 05-18-2013, 10:14 PM
85 was a four valve. More in common with the XR 250.
Similar Threads for: 85 XR200r blowin smoke.
New guy in Colorado with Honda XR200R Peterbilt_ Member Introductions 9 04-24-2013 01:32 PM
1985 XR200R rockland213 Classified Ads 1 04-25-2012 07:07 PM
XR200R 2000 Plastics xr200r rider 4-Stroke Dirt Bikes - Honda 1 11-12-2010 02:46 PM
Blowin' Stuff UP!!!!! LawDog101 General Discussion 16 02-06-2008 09:18 AM
XR200R Crank Needed! 8mag Classified Ads 0 11-05-2003 07:23 PM
