Old 05-22-2019, 08:59 AM
gusco's Avatar
Last Online: 01-09-2020 09:10 AM
Default 2010 CRF250R Air/Fuel Issues??
Hi y'all!
I picked up a 2010 CRF250R to flip. Found the service manual. I'm starting to clean it up to clear out the main issue that made it so cheap to pick up: It's hard to start and does not idle well. I figured probably valves.
I turned the idle knob nearly all the way up (literally a few clicks from the last one) and it started better and idled. I also checked the valve clearances last night and they are in spec (.15mm and .28mm). I also cleaned out the throttle body (it was pretty dirty). In disassembling, I found that the wires had been pulled out of the air temp sensor. I put them back, but I'm not sure they are in the correct orientation.
I'll try a test fire later today and report back. Anyone have any ideas of other things to check if it's still misbehaving?
Old 05-22-2019, 09:24 AM
Last Online: Yesterday 11:49 AM
I'd start with the obvious- fresh fuel, fresh oil/filter, clean air filter. Remove as many variables as you can to make isolating any issues easier.
Old 05-22-2019, 01:43 PM
Last Online: Yesterday 11:03 PM
Did you clean the fuel injector?
Old 05-22-2019, 03:10 PM
gusco's Avatar
Cowboy and PawPaw: good suggestions. I sprayed the inlet and outlet of the injector but don't have the proper tool to actuate it and spray through it. I'm either going to have to rig one up or buy one. I came home early from work and it took a bit to start. I'm hoping because the line needed to be primed. It started much better once hot though 1-3 kicks on 4-5 attempts. I'm letting it cool off to see what it does from cold now. If issues persist I'll pull the injector and clean it.
Old 05-22-2019, 05:32 PM
It sounds like the injector is leaking due to dirt and thus causing the engine to become flooded and hard to start. This would also explain the fuel line needing priming.
Old 05-22-2019, 07:32 PM
gusco's Avatar
I'll rig something up and report back.
---------- Post added at 07:32 PM ---------- Previous post was at 07:11 PM ----------
There does seem to be some unburnt fuel in there because I've had a few backfires in the exhaust.
Old 05-23-2019, 11:31 PM
gusco's Avatar
Got the fuel pump out and the filter was BLACK. Cleaned it up, but I'll be keeping it as a spare as one of the o-rings on the pump body was toasty. So, I'll be getting the filter kit that comes with a new filter and new o-rings. I also took out the injector and cleaned it out. Once I get parts in I'm hoping it fires right up. If not, I guess I'll move on to tps and coolant temp switch.
Old 05-24-2019, 07:24 AM
I have seen many cases where when the filter turns Black the pump is damaged due to the reduced fuel flow and reduced cooling to the pump. Using a fuel sock in the fuel tank can and will extend the fuel pump life.
Old 05-24-2019, 09:53 AM
Big Maico 393's Avatar
Super Moderator
Last Online: 12-25-2019 09:19 AM
You might try running some SEAFOAM thru it, once you get it to run for a bit.
Old 05-24-2019, 01:18 PM
gusco's Avatar
Thanks, fellas! Once the bike gets running, it seems to run fine aside from a bit of a bog when the throttle is stabbed quickly (it has been running without a filter in the garage though). I have a new air filter and fuel filter on their way. I don't have the correct specialty Honda tools to check fuel pressure (any ideas on how to check it??), but I can check the flow (150 cm3/ 10 sec). Once that system get checked out, I suppose some of the electrical components will be next: TPS, coolant temp switch, air temp switch, condenser.
Similar Threads for: 2010 CRF250R Air/Fuel Issues??
WANTED 2010-13 CRF250R (midwest) 0honda Classified Ads 3 03-22-2013 01:47 AM
2010 YZ250F fuel leak kosta24 4-Stroke Dirt Bikes - Yamaha 8 12-19-2011 09:37 AM
2010 CRF250R valve lifts and timings seiw 4-Stroke Dirt Bikes - Honda 2 02-05-2011 11:48 AM
2010 Graphics on a 2007 CRF250R Dolmankid 4-Stroke Dirt Bikes - Honda 2 09-08-2010 05:30 PM
2010 kawasaki kx500afx seized up,3rd tank fuel. madmick 2-Stroke Dirt Bikes - Kawasaki 2 08-02-2010 11:59 PM
