2006 CRF450R Clutch Noise???This is a discussion on 2006 CRF450R Clutch Noise??? within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; I been through a few threads on here about clutch noises, but nothing that is directly related to CRF's. First ... |
| I been through a few threads on here about clutch noises, but nothing that is directly related to CRF's. First of all, I've already did an oil change to see if that was the problem, but the noise is still there. The noise is like a clank or knock, but it only happens when I'm not pulling the clutch lever. When it's pulled in, even the tiniest bit, the noise goes completely away. Some of the threads on YZ's and YZF's say it's normal for some Yamahas to do that, could it be normal for CRF's too? I change my oil every two rides and i'm very particular about keeping up on maintenance. I haven't owned the bike long, but I swear I can't recall ever hearing this noise. Please help. |
| Does it do it when your are going fast or slow?Lugging or high RPM?Sounds like the chain is slapping on the swing arm. |
| The only time I notice the noise is when the bike is in neutral with the clutch lever out. |
| That is exactly what I was thinking. The honda does it bad, especially when lugging it. |
Hmm, I don't have any idea, but it's very easy to check the clutch and see what's up. Lay the bike on it's side (clutch side up). Remove the rear brake lever Remove the 10 or so 8mm bolts and take the cover off. You can then inspect to see what might be making that noise. |
My clutch basket in my little thumper is stock and ive been riding it for 2 and a half years |
| 05 bad clutch noise | sketchystreet | 2-Stroke Motorcycles - Yamaha | 2 | 07-21-2007 11:43 PM |
| 2006 crf450r and crf450x Choosing the right bike. | Stryke | 4-Stroke Motorcycles - Honda | 34 | 06-05-2007 02:29 AM |
| 2006 kx 85 engine noise | rednekoki | 2-Stroke Motorcycles - Kawasaki | 7 | 09-12-2006 09:05 PM |
| Getting A 2006 crf450r!!!!!!! | Stryke | General Discussion | 9 | 07-01-2006 05:51 PM |
| Clutch Noise | Monk-E | 2-Stroke Motorcycles - Yamaha | 3 | 02-06-2005 04:16 PM |
