Old 09-24-2012, 05:46 PM
Last Online: 02-25-2013 06:28 AM
Default 2002 xr200r won't idle
Hey guys, I have an xr200r 2002, I replaced the cam chain, tensioner, guide, and cam chain it's self. I did all the work then set the timing and put everything back in. But now the bike won't idle. I have taken all the jets out of the carb and cleaned them, cleaned the carb itself, and replaced all the seals in the carb. At the top of the engine along the top end seam on the exhaust side oil seeps out while its running. When running, I can hold it at a nice idle with the throttle, and when running, sometimes it runs through all the gears perfect and runs great and othertimes it Boggs down when given throttle. I have also replaced the air filter, I don't know what's left to do!! Please help! Maybe I am not tuning the carb right? Maybe it's the top end seal? I am out of ideas!
Thanks!
Old 09-24-2012, 08:09 PM
Last Online: Today 03:04 PM
Default OK
Ok, I know you said you cleaned the carb and jets, but I have found that most carb cleaners can't cut the crap deposited by our current "E" fuels in our carb jets. The pilot jet must be cleaned with a welders tip cleaner(wire) the break up the crap.
The other possibilities are a bad air leak at carb boot or intake or incorrectly set intake valves.
Old 09-24-2012, 08:40 PM
bbrmotosports's Avatar
Rockin A class
Like paw said, probably the pilot. I just had a customer with an XR bring a bike by. Said he cleaned the carb and same thing. The Pilot wasn't clean
Old 09-27-2012, 04:56 PM
I did actually clean the jets, I took them all out individually and cleaned the crystallization out of them with an E string from a guitar. I do have a welding tip file set I can try, but the string seemed to open them right up. If its not the jets being clogged could it be the adjustments/specs as far as how far in it goes? Would a clogged jet cause bogging when given throttle too? Also when I take the spark plug out it is solid black
Old 09-27-2012, 05:52 PM
Default OK
OK, so what is the fuel screw set at? It's the one under the front of the carb.
What condition were the valves in when you did the work?
Have you checked the float height? Can cause flooding and thus a black spark plug.
Have you done a compression test? What was the reading?
Old 09-28-2012, 06:51 AM
I set the pilot screw at 1 1/2 turns out from lightly seated and have tried fiddling with that and the idle screw at the same time. The valves didn't look new but they didn't look bad at all. I haven't checked the float height, ill do that next. I only have a compression guage for a car, so it wont fit the bike. So the float height being too high would cause a rich mixture?
Old 09-28-2012, 10:23 AM
I dont think you will be able to get any kind of guitar string through a pilot jet. hard to get hair through some of them
Old 09-29-2012, 09:36 AM
The e string of a guitar is 10 thousandths thick. And the average thickness of a human hair is about 4 thousandths. That's only a 6 thousandths difference. I think your referring to the wrong part.
Old 09-29-2012, 01:45 PM
Ok, so I adjusted the float, and now I can kick the bike into an idle with no throttle on and it will stay there great. But if I give it throttle it Boggs then gets stuck at a really high idle, then if I back the idle screw out it does nothing until...until it kills the engine, it's either high idle or off.
Old 09-29-2012, 02:51 PM
Default OK
Ok, air leak or sticking carb slide/
Oh yes, the pilot center orfice is smaller than .004" in most cases.
Similar Threads for: 2002 xr200r won't idle
2002 CR250 no idle and rich yoder_78 2-Stroke Dirt Bikes - Honda 8 10-20-2010 04:08 PM
2002 Rm250 idle problem (sudders) SnowX51 2-Stroke Dirt Bikes - Suzuki 4 01-22-2010 12:26 AM
2002 YZ250F idle and pipe red hot Parker 4-Stroke Dirt Bikes - Yamaha 3 12-23-2008 07:16 AM
2002 cr250 High Idle? kitsrider 2-Stroke Dirt Bikes - Honda 2 10-20-2008 10:10 AM
2002 ttr90 won't idle??? FULL-THROTTLE 4-Stroke Dirt Bikes - Yamaha 7 11-10-2004 07:01 PM
