Quantcast 1990 - XR600 - problems after sitting for 2 years
This is a discussion on 1990 - XR600 - problems after sitting for 2 years within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; Its my first post here and what a way to start!! I’ve just picked up an 1990 XR600…..she’s a little ...
Old 10-06-2008, 04:51 PM
Last Online: 10-07-2008 10:18 PM
Default 1990 - XR600 - problems after sitting for 2 years
I’ve just picked up an 1990 XR600…..she’s a little used and abused (farm bike) and I’m looking to fix her up for some off road action.
The issue is she has sat for 2 years (in a water tight shed in dry conditions) she kicks over ok, but is it going to be a case of having to give the engine a reco??
I know the XR’s have a solid engine, but would it be ok after sitting for 2 years???
I’ve also been looking at the suspension, the front is fine (but will put in new seals and oil) but the rear shock is the big issue…it compresses and slowly comes back up. Not sure if it’s the factory shock either, the remote canister has an adjuster on the top….is this factory???
With the shock behaving poorly on rebound, is it a case of re-gassing it or does it need a reco?? If so, are reco kits hard to find???
I know I’m asking a lot of questions, but any ideas and suggestions are welcome…
Cheers
Josh
Old 10-06-2008, 11:49 PM
I've been RM-Zedded
Last Online: Yesterday 07:11 PM
First off welcome to
I would drain the fluid from the gas tank, remove the carb and clean is thoroughly with carb cleaner, put it back together.
I would also make sure gas flows from the gas tank to the float boal.
As far as the shock, I'm sure a rebuild will fix it, and any suspension shop should be able to take care of that.
The Following User Says Thank You to Woody_393 For This Useful Post:
Josh636 (10-07-2008)
Old 10-07-2008, 08:57 AM
D3luxe's Avatar
Last Online: 12-30-2008 04:05 PM
Yeah, first and foremost you should clean out that carb. After sitting, especially if there was gas left in the engine, most likely the jets and possibly other parts of it will be clogged/gunked up.
And I agree, a rebuild of the shocks should fix your problem.
Welcome to !
The Following User Says Thank You to D3luxe For This Useful Post:
Old 10-08-2008, 03:00 AM
Last Online: 10-30-2008 04:28 AM
Give it a full service as fuel will be off and oil may have moisture in it. Check tyres for decomposition as they do go off and can be dangerous. And, always a good idea to remove plug and put a dash of oil in cylinder before you start it the first time when it hasn't turned over in years, but if you have already started it dont worry. The idea is to pre-lube the rings as they will be as dry as.
p.s. take the shock to the shop
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: 1990 - XR600 - problems after sitting for 2 years
XR600 Help please!!!! DMS01110 4-Stroke Motorcycles - Honda 4 07-18-2008 10:23 PM
I'll be sitting on the bench for a little while yzernie General Discussion 13 02-11-2006 12:33 PM
XR600 tire selection nate650 4-Stroke Motorcycles - Honda 3 01-23-2004 04:03 AM
XR600 sand blasting??? nate650 4-Stroke Motorcycles - General Discussion 10 12-10-2003 02:52 PM
KDX 200 sitting - Best way to get restarted? bobwilson2020 2-Stroke Motorcycles - Kawasaki 19 09-05-2003 11:38 PM
vB.Sponsors
Page generated in 0.14529 seconds with 12 queries
