03 CRF450r leaking coolant?This is a discussion on 03 CRF450r leaking coolant? within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; hey everyone i have a coolant leak coming from the weep hole under my water pump what is wrong and ... |
| hey everyone i have a coolant leak coming from the weep hole under my water pump what is wrong and how do i fix it. |
| If you want to get the impeller, no problem, but that is not your issue. Both my 03 and my 05 lost at least one impeller seal. It is a common problem. It is not a hard fix. You will need the following to do it correctly. 1. Rt. Crankcase cover gasket 2. Water pump cover gasket 3. impeller (if you want new one) 4. oil seal 5. water pump seal 6. water pump shaft 7. coolant Pretty simple fix. Take a look at your manual and you should have no problems. Be sure you put the seals in correctly. James |
| Oil leaking / Coolant weeping | lbzrider | 4-Stroke Motorcycles - Honda | 12 | 03-18-2009 10:53 PM |
| coolant still leaking | merky | 2-Stroke Motorcycles - Honda | 5 | 12-29-2008 03:07 PM |
| leaking coolant on my 2002 cr250 but not out of the rad | blake_vail | 2-Stroke Motorcycles - General Discussion | 9 | 06-19-2008 05:22 PM |
| 02 CRF450 leaking coolant? | CAD | 4-Stroke Motorcycles - Honda | 10 | 10-30-2006 08:34 PM |
| leaking coolant | 04blue450 | ATV/UTV - Yamaha | 8 | 03-07-2005 08:55 AM |
