02 CRF450 leaking coolant?
This is a discussion on 02 CRF450 leaking coolant? within the 4-Stroke Motorcycles - Honda forum, part of the 4-Stroke Motorcycle Forums category; Guy's, Ive got a 02 CRF450 here that is leaking a little coolant right near the waterpump. Its below the ...
Old 10-28-2006, 05:30 AM
CAD's Avatar
CAD CAD is offline
Last Online: 09-16-2007 06:10 AM
Default 02 CRF450 leaking coolant?
Guy's, Ive got a 02 CRF450 here that is leaking a little coolant right near the waterpump. Its below the waterpump coming from a small outlet hole. (see picture) Any idea what could be causing this? core plugs perhaps? coroded waterpump? Does it sound expensive? A mate seems to think its just a coreplug that needs to be replaced... is this a large job on this model? Thanks for any help!
Old 10-28-2006, 08:13 AM
Semper Fidelis
Usflag Re: 02 CRF450 leaking coolant?
I seem to remember an article about a weep hole on the water pump cover on this model. Maybe one of the Honda guys will clarify.
Bill
Old 10-28-2006, 09:31 AM
Vintage Dave393's Avatar
ATM History Professor
Last Online: 10-18-2009 07:09 PM
Default Re: 02 CRF450 leaking coolant?
If you have water coming from the weep hole, the water pump seal is bad. You need to order the seals, bearing and shaft. This was a common problem until the '05 model. In '05 Honda drilled a pressure equalizing hole in the water pump impeller that reduced the pressure on the seal. The new impeller will retro fit to the older bikes as well.
Old 10-30-2006, 12:33 AM
I've been RM-Zedded
Yep, very common. Order the parts, for your bike, and add an '05 impeller to the list and you'll be set.
Pretty easy job to do by the way, but let us know if you have any questions.
Old 10-30-2006, 12:37 AM
CAD's Avatar
CAD CAD is offline
Awesome thanks!
Old 10-30-2006, 04:44 AM
CAD's Avatar
CAD CAD is offline
So replace the impeller and washer (left)
and inspect the shaft for wear (right)
got it!
Old 10-30-2006, 06:36 AM
642MX's Avatar
Fat and Slow
Last Online: 06-19-2008 09:07 PM
Also check the balancer shaft. The balancer shaft drives the waterpump shaft. I've seen a few balancer shaft bearings go bad and cause the waterpump shaft to move around, which causes the waterpump to leak.
Old 10-30-2006, 02:11 PM
I've been RM-Zedded
got it!
According to the picture, reading from left to right, you should replace anything I have put replace next to: Shaft (replace), Oil seal (replace), spacer, case, Water seal (replace), washer, impeller (replace with '06 model), waterpump cover gasket (replace), and you'll need a new gasket for the side case that you'll take off (it's the big one they show in that picture).
Old 10-30-2006, 02:16 PM
Faded's Avatar
Last Online: Yesterday 07:33 AM
The new impeller wasn't introduced until the 2006 model year, the 2005 still has the (old) impeller without the hole. You can drill your own hole in your existing impeller if you wish, or just order the part. [Only registered and activated users can see links. ]
Old 10-30-2006, 02:19 PM
I've been RM-Zedded
Doh! Thanks Faded, I was wondering about that when it was posted, but just went along with the others like th sheep I can be at times
Old 10-30-2006, 08:34 PM
CAD's Avatar
CAD CAD is offline
Thanks guys, VERY helpfull!!
Similar Threads for: 02 CRF450 leaking coolant?
Oil leaking / Coolant weeping lbzrider 4-Stroke Motorcycles - Honda 12 03-18-2009 10:53 PM
coolant still leaking merky 2-Stroke Motorcycles - Honda 5 12-29-2008 03:07 PM
leaking coolant on my 2002 cr250 but not out of the rad blake_vail 2-Stroke Motorcycles - General Discussion 9 06-19-2008 05:22 PM
03 CRF450r leaking coolant? chriscrash 4-Stroke Motorcycles - Honda 1 05-13-2007 12:28 PM
leaking coolant 04blue450 ATV/UTV - Yamaha 8 03-07-2005 08:55 AM
