Old 04-06-2004, 04:09 PM
Supermoto's Avatar
Banned
Last Online: 12-27-2005 01:53 PM
Default 02-03 CRF
Hi,
can somebody point out the diffrences between the 2002 and 2003 CRF450 please.Cheers
Ben
Old 04-06-2004, 05:01 PM
Crogg's Avatar
Last Online: 03-14-2019 09:10 PM
Default Re: 02-03 CRF
Originally posted by Supermoto
Hi,
Ben
There are a couple of differences. First the airbox, filter, and cage was designed not to suck dirt like the 02 does. The exhaust was shortened to provide more snap as was the new cam. The swingarm pivot was lowered, and the spring rates were changed slightly. A few other odds and ends but the bottom line is this....get the 03!!!!
Old 04-06-2004, 05:20 PM
Faded's Avatar
Last Online: 12-11-2020 07:26 PM
  • Taller Seat (10mm)
  • Handle Bars Moved Forward (3mm)
  • "Improved" Foot Peg Location (Lower I think)
  • New Shock Linkage Raised Swing Arm Pivot (7mm)
  • Above Contributes to Steeper (27*) Steering Head Angle
  • Stiffer Rear Spring (5.5)
  • Revalved Front Forks w/Larger Piston and 10mm Longer Stroke
  • New Air Box
  • New Camshaft Profile
  • Shorter Pipe (50mm)
  • Revised Ignition Maps
  • Revised Carb Jetting
  • Lighter (232 lbs wet, no gas)
  • Longer Shift Lever (10mm)
  • Revised Clutch Damper for Improved Traction
  • Thicker, Stronger Frame Downtube
  • Stronger, Stiffer Cast Top and Bottom Engine Hangers
Old 04-06-2004, 05:36 PM
Supermoto's Avatar
Banned
Default CRF 02/03
Thanks for the treplys,are there any other diffrences I can see?like the exhaust,I'v been offered a supposedly 03 CRF,just wanted to check it is an official 2003 bike.
Cheers ben
Old 04-06-2004, 05:48 PM
Faded's Avatar
The 10th number on the VIN should be a 3 for 2003, or a 2 for 2002.
[EDIT] Revised list above to include more changes. [/EDIT]
