Go Back   All Things Moto! Web Forums > Reviews - Organized Rides - Recreation Areas - Classifieds > Product Reviews > Controls & Protection
Cleaning throttle or clutch cables?
This is a discussion on Cleaning throttle or clutch cables? within the Controls & Protection forum, part of the Product Reviews category; Does anyone have any trick's on cleaning the inside of clutch or throttle cables, to remove dirt. I have heard ...
Old 09-30-2007, 06:29 AM
pjg351's Avatar
Tie me Kangaroo down sport
Last Online: Today 01:55 AM
Default Cleaning throttle or clutch cables?
Does anyone have any trick's on cleaning the inside of clutch or throttle cables, to remove dirt. I have heard that there might be some tool or attachment that will do the job.
Old 09-30-2007, 12:26 PM
char393's Avatar
Incretacular!!
Last Online: 03-08-2010 09:33 AM
Default Re: Cleaning throttle or clutch cables?
Don't know about cleaning the cables, but we have a cable luber like this:
Old 09-30-2007, 12:53 PM
crfjedi393's Avatar
Obi Wan Kenobody
Last Online: Yesterday 03:43 PM
A few shots of WD-40 after every couple of rides works wonders.
Old 09-30-2007, 02:32 PM
pjg351's Avatar
How does that work Char? I can see that it must tighten around the cable, but iam not sure about how it lubes.
Old 09-30-2007, 02:34 PM
char393's Avatar
Incretacular!!
This explains much better than I could...
Old 09-30-2007, 02:39 PM
mxmama393's Avatar
Niffer
Last Online: 01-23-2010 08:55 PM
I was too scared to ask that.
Im so glad you did!!!
Old 09-30-2007, 02:45 PM
pjg351's Avatar
Thanks for that Char, that sounds like the one I was told about. Cleans and lubes the whole length of the cable, now i just have to find out where to get one!
Old 09-30-2007, 02:47 PM
char393's Avatar
Incretacular!!
Not sure what's available on your side of the world Pete, but you should be able to get them through any mail-order place.
If you can't find one, let me know, I'll pick one up for you at the local shop and send it over snail mail.
Old 09-30-2007, 03:06 PM
pjg351's Avatar
I just up a couple of sites here in Aus, so i will try them first. There also might be another type that works under some type of pressure cleaning method, so i will check that out too!
Old 11-06-2007, 11:51 AM
jloev1974's Avatar
no such agency
Last Online: 06-25-2009 11:17 AM
I use a cable luber that I got at Cycle Gear for $6, and then use WD40 to flush out the goop that was in there before. You have to have the straw on any aerosol with the luber, and if you shorten it, it works better (doesn't pop out).
After cleaning the cable out with WD40, then I use brake cleaner and let it dry. After that, Dupont Dry teflon lube is the best (and final) lube. It doesn't attract dirt like chain lube and makes for a near-effortless cable action.
Similar Threads for: Cleaning throttle or clutch cables?
2001 Yz 125 clutch and throttle problems. Sean9224 2-Stroke Motorcycles - Yamaha 6 12-14-2008 06:33 PM
aftermarket cables? hainitracing General Discussion 5 05-02-2004 04:11 PM
Throttle Cables / Carb Cleaning Satch0922 4-Stroke Motorcycles - Yamaha 7 04-05-2004 08:51 AM
YZF Guys - Check your throttle cables! Keetoman393 4-Stroke Motorcycles - Yamaha 12 09-23-2003 06:52 PM
Thumper riders Check your Throttle cables Ranger_450F General Discussion 8 09-04-2003 10:30 PM
