Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Exotic
wheres my clutch fluid?
This is a discussion on wheres my clutch fluid? within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; i have a 2001 tm 125 and my clutch fluid keeps dissapearing.is it leaking into the crankcase from a seal?how ...
Old 08-27-2009, 09:31 AM
Last Online: 09-29-2009 09:45 PM
Default wheres my clutch fluid?
i have a 2001 tm 125 and my clutch fluid keeps dissapearing.is it leaking into the crankcase from a seal?how hard and expensive is that seal to replace?
Old 08-27-2009, 10:13 AM
Are you talking clutch fluid for hydraulic clutch? If so there is no way for it to leak into the crankcase, it would either be leaking at the master cylinder up on the bars or at the slave cylinder down on the motor.
Old 08-27-2009, 05:12 PM
ya for a hydraulic clutch.um i bleed the clutch and then everytime i pump the clutch , the level keeps going down.i have put 250ml in it already .i put a peice of cardboard on the ground underneath and nothing is dripping on it.
Old 08-27-2009, 06:28 PM
You must still have some air in the system somewhere. I'm not sure what brand clutch you have or the proper bleeding method, but you might be able to find some directions by doing a search on Google.
Old 08-27-2009, 06:52 PM
your positive that it cant leak into the crankcase?
Old 08-27-2009, 08:58 PM
Not 100% but I've never seen a hydraulic clutch setup that was internal to the cases in any way. You should have the master cylinder, a hose, and a slave cylinder. The slave cylinder should have a rod that when the clutch lever is pulled moves out and pushes the arm that is the linkage that pushes out on the pressure plate and disengages the clutch (I hope that made sense). A photo is worth 1,000 words, if you can get a pic of your setup post it up!
Old 08-27-2009, 09:19 PM
ok sounds good.thanks for your help
Similar Threads for: wheres my clutch fluid?
Wheres this go? Supermoto 2-Stroke Motorcycles - Honda 13 10-20-2005 07:53 AM
Wheres Smithers again? smithers General Discussion 12 08-30-2004 05:21 PM
Wheres Smithers been? smithers General Discussion 17 06-24-2004 05:42 PM
Looking for fluid specs for 97 CR 250 Deak 2-Stroke Motorcycles - Honda 2 09-19-2003 09:44 PM
