Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Exotic
(Noobee)Trouble starting sons 49CC Pocket dirt bike
This is a discussion on (Noobee)Trouble starting sons 49CC Pocket dirt bike within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; Guys , I just bought my 5 year old son a 49cc Pocket dirt bike ( not the best quality ...
Old 06-19-2008, 12:46 PM
vinnie187's Avatar
Last Online: 06-23-2008 02:46 PM
Default (Noobee)Trouble starting sons 49CC Pocket dirt bike
Guys ,
I just bought my 5 year old son a 49cc Pocket dirt bike ( not the best quality ) but its his first bike and I wanted something cheap for him to start out on , the only thing is I am having a heck of a time starting it . It is furnished with a pull start and I yanked on it about 100 times and it would not start. I have the correct fuel to oil ratio 50:1 , I checked the spark plug it was a bit fouled from the first ride but I since cleaned it and reinstalled it (still "no dice") . Cleaned the air filter , buggered around with the mixing screw (nothing) . I am totally new at this but willing to learn , I am determined to solve this problem on my own without having to bring it in to a shop , guys where should I start ? any advise would be greatly appreciated , thanks in advance .
Old 06-19-2008, 01:52 PM
Riptide369's Avatar
Crash
Last Online: 10-08-2009 09:57 AM
Default Re: (Noobee)Trouble starting sons 49CC Pocket dirt bike
Check the kill switch. Heard they can sometimes stick and ground out. Just a thought. You try bump starting it?
Old 06-19-2008, 01:58 PM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 11-12-2009 01:21 PM
Originally Posted by vinnie187 View Post
Guys ,
Even when jetted correctly those bikes are trouble when trying to start, it gets better after break-in. ...and don't kill yourself cranking it or you'll break the starter prawl (don't ask ). Use a NEW plug and freshER gas (with a little less pre-mix oil (lean side?). Give her another few cranks and it should do the trick. From your note, I assume you started it before.
Oh yeah this site will come in handy too [Only registered and activated users can see links. ]
.....I'm the neighborhood expert on these junkers (not really by choice)
Old 06-19-2008, 02:05 PM
Riptide's suggestion would also be a real good place to start
Old 06-19-2008, 04:50 PM
vinnie187's Avatar
Thanks Guys ,
I will put a new spark plug in and throw fresh fuel in , Pragmatic393 yes I did get it started in the past , it was hard to start then , but when it warmed up it started in a couple of pulls with the throttle cracked a bit , Pragmatic393 what do you suggest for a ratio ? Riptide369 , how do I go about testing the kill switch ?
Old 06-19-2008, 05:05 PM
Riptide369's Avatar
Crash
[QUOTE=Riptide369 , how do I go about testing the kill switch ?[/QUOTE]
I would try to disconnect it from the wire harness, then try to start it. If it starts then the button is making contact in the switch.
You try cussing at it? It normal doesn't help but sure makes you feel better
Old 06-19-2008, 09:24 PM
quadrunner250's Avatar
Last Online: 04-09-2009 05:05 PM
lol good suggestion use the f word a couple times then throw in a b word or two and should start right up lol
Old 06-19-2008, 09:28 PM
Synyster06Gates's Avatar
ATM's UGer.
Last Online: 09-09-2009 08:09 PM
That's what I used to do with those little 2 stroke scooters, haha.
Old 06-20-2008, 08:44 AM
Thanks Guys ,
I don't think all the stock carbs have a replaceable jet (hence all the starting problems). I hate to recommend a ratio that'll fry the lil thing but 60:1 i about the ratio that works well in ours. Start with that and add a bit more oil on the next tank Heck, I think I have a few of the lil chinese terror bikes around the house, If you bomb it I'll send you another one fo free J/K
Oh yeah, check the chain tension and exhaust header bolts very often. Those bikes are freaking rattle traps.
Old 06-22-2008, 11:05 PM
vinnie187's Avatar
Guys
Checked the kill switch ,wasn't the problem , and cleaned the spark plug real good Not sure what I did but , i was fiddling around with the carb and I disconnected the fuel line between the tank and the top of the carb just to assure it was getting fuel and that the hose was not clogged ..... so when I removed it there was a steady supply of fuel , I connected the hose back up and for the heck of it I tried starting it ........ to my surprise it fired right up after a coupe of pulls ??????? What do you guy think ..... some sort of air lock within the carb?
Old 06-23-2008, 09:13 AM
Guys
Gremlins or evil spirits, you set them free..works every time. Start there next time
Excellent
Similar Threads for: (Noobee)Trouble starting sons 49CC Pocket dirt bike
Sons bike Zman510 Member Introductions 2 12-03-2008 11:37 PM
gah once again more trouble with this dang bike 2001hondacr125 2-Stroke Motorcycles - Honda 5 02-11-2008 05:56 PM
pocket bike ktmkid358 Misc Riding Types 6 12-09-2004 09:30 PM
49CC Mini Harley VER. 2 POCKET BIKE BLACK Rakk67 Motorcycles & ATV's 3 02-25-2004 04:14 PM
rm250 trouble starting butlerox77 2-Stroke Motorcycles - Suzuki 7 02-21-2004 12:58 AM
