Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Exotic
Newbie with a carb problem
This is a discussion on Newbie with a carb problem within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; Novice needs some direction… I’ve been reviewing some past forum posts of related problems but am still a little confused ...
Old 06-13-2006, 01:09 PM
Last Online: 06-18-2006 10:00 AM
Default Newbie with a carb problem
Novice needs some direction… I’ve been reviewing some past forum posts of related problems but am still a little confused as to where to begin. My 02 CR125 Husqvarna bogs badly when the throttle is nailed. Runs decent if you keep it under half throttle but as soon as you get hard on the gas it bogs/dies. Sometimes, if you sneak up on the revs, it runs fine and screams at full throttle. Otherwise, if you just nail it, it dies. The bike idles fine, runs fine if not wide open and always starts fist kick. My guess is a carb problem. I’m not the original owner so I have no idea what the current jetting is. Going to clean the carb and check the float level… Just looking for some additional suggestions. Thanks
Old 06-13-2006, 01:36 PM
crdemon's Avatar
THE REAL REBEL RIDER
Last Online: 05-14-2008 09:59 PM
Default Re: Newbie with a carb problem
WELCOME TO !!!
Sounds like ur headn in the right direction. Have you ever changed the plug? does it foul spark plugs? Check your reeds while you have your carb off, inspect for chips.
Old 06-13-2006, 02:59 PM
KKXR400R's Avatar
V26X INT
Last Online: 11-19-2009 07:54 AM
Hey, Welcome to ATM. Your definatly heading in the right direction with cleaning the carb and checking the float level. The Knowledge base threads are really helpful. Knowledge base If you get into a bind just type away. Good luck
-Kevin-
Old 06-13-2006, 03:02 PM
KKXR400R's Avatar
V26X INT
Sorry for posting twice here but one other thing you may want to try. The next time you go out, turn your choke on and see if that helps the off idle response. If it does, you may have a lean in the air screw, pilot and/or needle area. See ya
-Kevin-
Old 06-13-2006, 07:30 PM
Semper Fidelis
I hope Faded or OSSA GP1 picks up here but I'll offer that a sticking closed float needle may be giving you the problem. Just a hunch, I'll see if the true gurus can get on this one for you.
Best of luck and Welcime to ATM
Bill
Old 06-13-2006, 07:53 PM
KKXR400R's Avatar
V26X INT
ouch Alright buddy its on now! .......I'll admit I'm just a half guru when it comes to these carb questions When it comes to jet propulsion or nuclear fusion FADED and OSSA are pretty damn good....did I mention they can really help with jetting?
Old 06-13-2006, 09:26 PM
Semper Fidelis
Talking Re: Newbie with a carb problem
Oops, Sorry Kenny Didn't mean to belittle you at all. You do a terrific job here, too. I just like to get the "Old Guys" (HeeHee) to look at things. I know, I know I have over 30 years of age on Faded, just a lame joke.
Seriously, Kenny is someone to listen to, he is knowledgeable and pretty understandable to boot. Listen to his advice.
Is that a start Kenny: ?
Bill
Old 06-13-2006, 10:30 PM
KKXR400R's Avatar
V26X INT
Who's Kenny?
Old 06-14-2006, 02:52 AM
Semper Fidelis
Red face Re: Newbie with a carb problem
OOps again, pain meds old friend. I'll get it right some day Kevin, Kenny, at least I had a K as the first letter (dang it, out of excuses for bone headed move)
You are still someone to listen to anr one of the good guys. maybe its South Park on the brain tonight.
Bill
Old 06-14-2006, 09:53 AM
You can tell a lot by just looking at the plug after trying a full throttle run. Set the float,,clean etc,,and if it still is running poorly try it again, and look at the plug. Also note whether it smokes a lot,,,runs and misses like it is about to clean out, or just goes on it's face. If it is the latter it is usually jetted way lean. The former, (and leaving a black or oily black plug) it is too rich. Check those things out and write back.
Old 07-04-2007, 04:13 AM
Last Online: 11-10-2009 10:41 AM
if hes gotta "sneak up" on the throttle to get it to screem the main jet is way to lean. the slide cutaway may also be too lean. the needle may be to lean. Do plug checks for sure as ossagp1 says. the light tan to white color is going to tell you way too lean. what do you mix your oil at? i belive 32:1 is where you should run on a hot day, and 36:1 - 40:1 on a cold day. also, if you find its too lean, drop the clip possition on the needle one notch and test it out. if you think its close and it seems like it is running fine, ride on for about 10 minutes at the usual ride pace you do and then check the plug's color. you dont want it black or greasy looking. you want a chocolate color to mocha tan color.
Old 12-13-2007, 03:34 PM
Last Online: 08-15-2008 12:01 PM
What plug are you running? My '06 did the same thing right after I took out the resistor plug and went with a standard B8ES. Husky dealer says get the resistor back in, as the ignition is programed to shut things down at higher RPM is a non-resistor is run.
Similar Threads for: Newbie with a carb problem
Carb problem brlatm 2-Stroke Motorcycles - General Discussion 6 10-12-2007 02:03 PM
97 RM125 carb jetting for newbie inf0r 2-Stroke Motorcycles - General Discussion 28 03-06-2006 10:55 AM
02 carb problem 1500cr250 2-Stroke Motorcycles - Honda 9 10-27-2005 10:21 PM
Carb Problem Need Help dinorex44 2-Stroke Motorcycles - General Discussion 22 01-24-2005 02:55 PM
Carb problem RacerCR125R 2-Stroke Motorcycles - Honda 10 07-22-2004 08:40 PM
