Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Exotic
Husky CR250 Carb problems
This is a discussion on Husky CR250 Carb problems within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; Hi I have a 1999 husky cr250 which has carb problems. My initial problem was that the slide had worn ...
Old 02-17-2006, 12:08 AM
Last Online: 02-17-2006 03:02 PM
Default Husky CR250 Carb problems
Hi
My initial problem was that the slide had worn & that the needle was sticking in the emulsion tube. as no parts were available in south africa I polished the needle with water paper in a dremmel, this gave me very high fuel consumption.
I ordered the honda cr250 2002 mod slide, needle & emulsion tube from mx south as this uses the same mikuni tmx carb as the 2002 honda. I am running a 380 mainjet, 30 pilot jet & a 6bey30-75 needle in the second position from the bottom ie 4th from top my fuel consumption is still high.
Question how do I check & set the float hieght.
ambient tempreture is about 25deg celcius where I stay at 5000 ft asl
does anyone have any advice on jetting?
Thanks Chris
Old 02-17-2006, 12:42 AM
char393's Avatar
Incretacular!!
Default Re: Husky CR250 Carb problems
Hi Chris and welcome to ATM.
I'm not sure if this will help you or not, but you should have a look at this thread by Faded;
How To Set Your Motorcycle Carburetor Float Level
I'm sure the jetting gurus will be along shortly to better answer your questions.
Old 02-17-2006, 07:38 AM
dbc dbc is offline
Check out this site. [Only registered and activated users can see links. ]
The folks there should be able to help you out.
One cool thing about Husqvarna is that you can download manuals in pdf form from their website. The service manuals don't go back to '99, but the "how-to" on float adjustment should help.
If your still having trouble finding the exact float level for your model, call Dan at Motoxotica, he should be able to help you out.
Old 05-10-2006, 07:22 PM
Huskyrider146's Avatar
no rice burner for me
Last Online: 07-31-2007 12:06 AM
alot of the older huskies had problems with the carbs...... dont know what would be a good solution
Old 05-10-2006, 09:45 PM
HiG4s's Avatar
Last Online: 10-29-2009 09:37 PM
Originally Posted by Chris l
Hi
Thanks Chris
for parts did you check with Italmoto SA, 30 Poplar road, Primrose. +27-011-828-8602
They are a Cagive dealer and Husqvarnas are all built in Italy in the Cagiva factory since 85,, the Cagiva Mito has the same engine.. not the same carb though.
Old 03-14-2009, 11:31 PM
Last Online: 03-15-2009 02:45 PM
Default need help plz
i just bought a 86 cr250 and i had it running but when i hit the gas it wouldnt kick the power band in it seemed like bad gas or dirty carb. i cleand the carb a few times,air box, also the reeds everything looked good. it has a keihin carb on it. what r the settings for the carb??
Similar Threads for: Husky CR250 Carb problems
carb. problems.... reeseyz125 2-Stroke Motorcycles - Yamaha 7 04-06-2009 08:13 AM
88 husky 250WR engine rebuild, need husky expert advice yellowsnow Vintage Riding 3 12-06-2008 06:06 PM
2005 CR250 carb problems dirtrider15 2-Stroke Motorcycles - Honda 1 06-10-2007 10:10 PM
2001 CR250 carb/jetting problems ryancr500 2-Stroke Motorcycles - Honda 24 08-30-2006 12:52 PM
CR250 carb problems (1988) CheM 2-Stroke Motorcycles - Honda 5 02-05-2005 10:38 AM
