Quantcast 2-stroke cagiva
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - Exotic
2-stroke cagiva
This is a discussion on 2-stroke cagiva within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; 1987 Cagiva WMX500 Purchased about three years ago. For 150 I thought it would be a turn and burn,boy was ...
Old 12-22-2006, 07:06 PM
Last Online: 12-22-2006 08:00 PM
Default 2-stroke cagiva
1987 Cagiva WMX500 Purchased about three years ago. For 150 I thought it would be a turn and burn,boy was I wrong. It started with fuel in the crank case, gone now , 100's of kicks and still no fire. No manual,no notta. Parts are hard to find in the U.S. Has spark, I cleaned the carb, still had no luck. Started to play with float, now I get 2 or 3 kicks then a backfire. Any advice would be greatley apreaciated.
Old 12-22-2006, 07:38 PM
Vintage Dave393's Avatar
ATM History Professor
Last Online: 09-24-2008 10:41 AM
Default Re: 2-stroke cagiva
Ok, here goes
  • check the reeds, if they're chipped or broken you'll have this problem
  • pull the pilot jet and make SURE it's clean
  • check the compression with a tester, less than 100 lbs = bad
  • do you have a fat spark, or a little spark?
  • dribble some gas in the spark plug hole and give it a try, if it fires you definately have a fuel problem
Let us know what's going on and we'll get you running.
Old 12-22-2006, 08:12 PM
Florida 393's Avatar
Semper Fidelis
Last Online: Today 11:59 AM
Usflag Re: 2-stroke cagiva
Cagivan,
I moved posts around, this is Dave, he or one of our resident experts can help you greatly. Best of luck with the WMX-500, keep us posted.
Bill
Old 12-22-2006, 09:10 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Today 01:31 PM
Cagivan:
Welcome to the site.
all I can add to Dave's info is it might be timing, I'll see if I can get in touch with my friend in Italy & find you a manual for your WMX 500.
Old 12-25-2006, 03:44 AM
jason33's Avatar
Last Online: 01-06-2008 08:16 PM
check the magneto- to see if the woodruff key-(moon key) is broken
-compression- if its under 150-re ring it
check the float height-,and turn the carb upside down and blow through a longer fuel line- make sure the floats are shutting off the fuel
it sounds like a bad needle and seat or stuck floats,letting fuel flow into the cyl (yes) -even while its not running-
check all ground wires ,and connections- keep us posted let us know what was wrong-
where you at you wanna sell it?
Old 12-25-2006, 02:33 PM
HiG4s's Avatar
Last Online: Yesterday 09:12 AM
Back in 86 Cagiva bought the Husqvarna name moved all the manufacturing to Italy in 87, but kept both names for a few years.
I believe the WMX500 was sold both under the Cagiva and Husqvarna name.
Now only street bikes have the name Cagiva and all their dirt bikes are sold under the Husqvarna name.
Husqvarna dealers should be able to order parts for you.
Premier Motorsports
301 W. Deer Valley Rd., Suite 10
Phoenix, AZ 85027
Phone: 623-582-1350
Fax: 623-582-9971
Email: [Only registered and activated users can see links. ]
Prowler Powersports
7956 S. Priest Dr.
Tempe, AZ 85284
Phone: 480-705-5300
Web: [Only registered and activated users can see links. ]
Sunburst Motors
324 S. Montezuma St.
Prescott, AZ 86303
Phone: 928-445-2500
Fax: 928-443-5537
If not, here is the only Cagiva dealer in AZ..
Renaissance Motorcycles
5844 East Speedway Blvd.
Tucson AZ 85712
Phone: 520-747-2647
Fax: 520-747-2647
Website: [Only registered and activated users can see links. ]
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: 2-stroke cagiva
2 stroke to 4 stroke convert ride report 02mncr250 General Discussion 9 01-17-2006 03:20 PM
Open Class, Enduro, Onroad/Offroad mullet1 General Discussion 3 05-19-2005 09:01 PM
2 stroke vs. 4 stroke question Blaster2678 2-Stroke Motorcycles - General Discussion 4 01-27-2005 11:10 PM
2 stroke vs 4 stroke telecomslave General Discussion 3 06-22-2004 05:42 AM
2 stroke vs 4 stroke theory & cluelessness MegaDeTH General Discussion 15 10-26-2003 12:53 PM
vB.Sponsors
Page generated in 0.18205 seconds with 12 queries
