1986 husqvarner 250 problemThis is a discussion on 1986 husqvarner 250 problem within the 2-Stroke Motorcycles - Exotic forum, part of the 2-Stroke Motorcycle Forums category; need help when i start the bike it revs out of control like the throttle is stuck
but its not ... |
| need help when i start the bike it revs out of control like the throttle is stuck but its not stuck.just finished restoring the bike.any suggestions? |
| i had the same problems with my yz250, different model, but sounds like the same problem, its too lean. start small and check to make sure the slide in the carb. is seating properly, and that ur throttle assembly is not binding. Go thru and clean the heck out of the carb with carb cleaner. if that doesn't work then maybe you could check your jetting and idle adjustments, set them to stock (given in your Manuel if you got one...). could also be a leak, extra air getting into the motor... -nic |
| 1986 RM 80 | shauny35 | 2-Stroke Motorcycles - Suzuki | 6 | 06-25-2009 05:12 PM |
| 1986 husqvarner 250 problem | dsmigneault | 2-Stroke Motorcycles - Exotic | 3 | 03-31-2008 02:55 PM |
| 1986 yz80 | yankbuilt | 2-Stroke Motorcycles - Yamaha | 4 | 11-01-2007 11:01 AM |
| 1986 CR 125 Problems | CR125 | 2-Stroke Motorcycles - Honda | 10 | 05-24-2006 01:55 AM |
| 1986 YZ 80 for $350 | Woody_YZF | General Discussion | 36 | 05-12-2004 10:17 PM |
