Weight loss formula for an office contest?This is a discussion on Weight loss formula for an office contest? within the Fitness, Training, & Recovery forum, part of the Miscellaneous Forums category; I wanted to try a Biggest Loser style contest at work. I was wondering what kind of mathmatic formula I ... |
| I wanted to try a Biggest Loser style contest at work. I was wondering what kind of mathmatic formula I could use to make it fare. I looked at the TV shows site and (without joining) the info I'm looking for is not available. How would you make it equal to lose 50lbs compaired to someone needing to loose 20lbs to meet their medical weight? Would the overall % be higher on the individual who needs to lose less weight? Should people that need to drop 20lbs or more only play? I should be able to figure this out |
| Can't you take everyones weight before and then take the lightest person and then take the amount of weight they are going to lose and then figure out what percentage of body weight that would be and then use that percentage for everyone else......................if that makes any sense. |
| They are doing the same thing at my work just a little different. Everybody has to put in $200 into the pot. The goal is to lose 10% of your body weight. The people that lose 10% of their body weight devide the money in the pot equally between them all. Losers do not get anything. If nobody loses 10% of their body weight all the money in the pot will be donated to a diabetes charity. They had 15 people join so its a nice pot. |
| Thats what I'm getting at TDC. Do I use the slimmer person as the base for the formula? The % of weight harder for someone 15lbs out of shape to lose as someone who is 70lbs over weight? I would like everyone the chance to join in. I just don't want an easy win to take it. This is why I may make the contest for those that need to lose 20lbs or more. I was thinking of using the National adverage to base all the goal weights too. Yeah I still can play at the 20lb cut off |
| I kinda like Jdryder's idea about using a % of body weight. That way it keeps it fair. and then figure out how much each person has to drop to meet that percentage. |
| Figure out how much each person needs to lose in order to be at their "ideal" body weight. Calculate the difference between current body weight and goal body weight. Now you should have a number like 50 lbs. When the contest is over, calculate what percentage of of that number was lost. Example: current weight is 200 lbs goal weight is 150 lbs Goal to lose: 50 lbs Actual lost: 25 lbs or 50% of goal. the down side is that those with more to lose will have less time to lose it compared to someone with less weight to lose. For example, someone who needs to lose 100 lbs vs someone who needs to lose 50 lbs will have a much harder time losing twice as much weight in the same amount of time. |
| TDC I think your right about JD's idea. JD your the man! |
| Weight loss? | minus16969 | Fitness, Training, & Recovery | 20 | 11-29-2007 09:55 PM |
| D-37/Offroad Community Loss | Dirtbikindad393 | General Discussion | 9 | 01-09-2007 11:42 PM |
| Tragic D-37 loss | Florida 393 | General Discussion | 6 | 11-02-2006 07:08 AM |
| Yamaha Office Raided by Japanese Police | boogieonmyfinger | General Discussion | 5 | 01-25-2006 06:01 PM |
| Loss of top end power.... | AceYZ250 | 2-Stroke Motorcycles - General Discussion | 8 | 10-07-2005 03:31 PM |
