Go Back   All Things Moto! Web Forums > Miscellaneous Forums > Fitness, Training, & Recovery
How do ride with the heat?
This is a discussion on How do ride with the heat? within the Fitness, Training, & Recovery forum, part of the Miscellaneous Forums category; Hey, here in socal or hemet it is pretty warm. Probally like 90+. My step dad usually takes me riding, ...
Old 05-31-2004, 09:31 AM
GopedTTr's Avatar
Last Online: 03-09-2010 12:46 AM
Hey,
here in socal or hemet it is pretty warm. Probally like 90+. My step dad usually takes me riding, but now with the this heat he isent liking the idea.
What are some ways to keep cool as your riding in the heat? I've camel backs but they are so expensive!
Thanks for anyhelp!
Old 05-31-2004, 09:48 AM
MotoMojo17's Avatar
Pinger-Slinger
Last Online: 09-04-2009 11:37 AM
Default Re: How do ride with the heat?
there is some kind of neck pad you can buy and it is supposed to lower your body temperature a whole lot and makes it really easy to ride in the heat...cant think of the name but im sure someone on here knows what im talking about
Old 08-31-2004, 02:50 PM
Katy's Avatar
..crazy, I was crazy once
Last Online: 08-17-2005 01:36 PM
I try getting out really early or really late...just avoid major heat alltogether
Old 08-31-2004, 03:13 PM
CRF731's Avatar
Traveling the world
Last Online: 01-15-2010 07:46 PM
Here are a few suggestions that helped for me.
Pick up a set of vented gear so the wind will blow through it to help cool you off. I use Thor AC5.
A higher priced helmet usually is ventilated better that the lower priced ones. I use a Shoei VFXR.
Try and get out early in the morning or later in the evening to avoid the hottest time of the day.
The first two suggestions are going to cost a lot but the last one is pretty cheap. I haven't tried one of the neck things that you soak in water that someone else mentioned but I have seen them in sporting good stores. They are cheap so it would be worth a try. Sometimes it is just to hot so I stay home and wait for cooler days.
Old 08-31-2004, 03:40 PM
mxrider's Avatar
Last Online: 10-20-2006 05:17 PM
I just dont wear all my gear..only my helmet and gloves....I would die from the heat if I had all my gear on.....remember to bring alot of water too...
Old 08-31-2004, 03:41 PM
mxrider's Avatar
Oh yeah..wear jeans instead of your riding pants...Jeans protect u as much and arent as hot.....esspecaily if you have holes in them from skateboarding..lol
Old 08-31-2004, 03:56 PM
zuki's Avatar
Last Online: 03-05-2010 01:02 PM
Ive found camelbacks helpful:
Old 08-31-2004, 04:19 PM
Garasaki's Avatar
Woods Rider
Last Online: 04-22-2009 07:24 AM
I would go as far as to say don't listen to a word this person says. :
They are only like 30 bucks. They definately will make riding in the heat safer.
Another easy tip is to cut some holes in an old jersey. That helps keep ya cool. Cut a few in the back, and some under the arms and on the side of your chest. Probably best to keep the front and the arms intact.
Really, the heat isn't terrible when you are riding. But when you crash, or stop riding for some reason, the heat suddenly catches up to you. There's really nothing worse then crashing in the heat...
Old 08-31-2004, 04:48 PM
psyklone393's Avatar
...dress for the crash...
Last Online: 03-27-2006 10:53 AM
i second the vote for the thor ac5 gear. it can be expensive if you don't shop around. i got mine new on ebay, the jersey was $25 and the pants were $50.
get out and start riding early. when we hit trails in the texas summers we get out there as the sun starts to rise and usually we're done by the time it starts to get toasty.
also, if you're riding trails, get out of the trees once in a while. if you can get in an open area now and then you'll get some breeze that you won't get when you're up in the trees and trails. you'll appreciate it, and chances are your bike will too.
-Z
Old 08-31-2004, 04:58 PM
drman's Avatar
Fender B...reaker!
Default Re: Re: How do ride with the heat?
True dat. Jeans rip SOOOO easy...I've had pairs completely rip in just first gear tipovers...
Old 08-31-2004, 05:13 PM
mxrider's Avatar
i dont know what kinda jeans u guys get but my jeans protect me....
Old 08-31-2004, 06:17 PM
CR-FLAVOR's Avatar
real fartsmeller
Last Online: 12-01-2008 08:49 PM
get cheap pants, cut them into shorts, cut the sleeves off your jersey, and cut it shorter, then wear a vented chest protector over it.
dude, you are in socal, hit me up with a PM. im in OC
Old 08-31-2004, 06:30 PM
zachrider's Avatar
SoCal
Last Online: 04-23-2008 12:02 AM
a camelback and those cool airconditioning neck things from sharper image are the way to go
Old 08-31-2004, 06:44 PM
twoofeach's Avatar
AKA clicea
With the exception of Texas, everyone chiming in is from Alberta or some other cold region where it actually snows. They know nothing of serious heat.
Get out like "pack the gear up the night before early". Get your ride on and get out. OR wait until the fall. Jeez, I've been riding in this heat and it's not real healthy. I wouldn't recommend it. I swear I have felt the begining stages of heat stroke. The sad part is, it might have been hours before I got some kind of help. I started dry heaving, lightheaded and the scariest, I stopped sweating. Make sure you go with someone, that's a good idea regardless of the weather.
Old 08-31-2004, 06:47 PM
twoofeach's Avatar
AKA clicea
Another thing, enough with the cutoff's. Riding in shorts is for freestylers. How 'bout, ride without a helmet, that'll keep you cooler. Please, if you were really that dumb, by all means do the rest of us a favor.
Old 08-31-2004, 07:28 PM
mxerncolo's Avatar
Last Online: 10-23-2006 11:08 PM
Going this Friday morning to the track at Berthoud, Colorado if anyone's interested - sorry, days off are Friday/Saturday...
AND I WILL have the camelback along (two extra in a cooler?),
AND I'm not going to be interested in impressing any "girlz,"
AND my premix is 32:1 Belray HR1,
AND... what else...
Oh, AND I'll not worry whether or not ATM has become a teen forum.
I'm jest goin' ridin.'
jim
P.S. I'll be the one in full gear as it seems there's an ambulance there most every day to transport some hapless... uh person... to the emergency room because they went riding on a MX track in a pair of shorts, a T-shirt and a pair of $100.00 tennis shoes. [and invariably one shoe is found lying 100 yards away from the other]
Old 08-31-2004, 08:32 PM
Satch0922's Avatar
Heat? What Heat?
The key is to ride as fast as you can, have plenty of water iced down and bring an EZup.
The Thor AC gear helps ALOT!!!!
Old 08-31-2004, 08:45 PM
char393's Avatar
Incretacular!!
Last Online: 03-08-2010 09:33 AM
AND... what else...
jim
Nice jim...very nice. You crack me up.
Old 08-31-2004, 10:05 PM
desertfreak's Avatar
Last Online: 08-17-2005 10:24 PM
dump water all over your head and ride fast that works good for me when im desert raceing in the hot sandy desert
Old 08-31-2004, 10:27 PM
CRF731's Avatar
Traveling the world
[QUOTE]Originally posted by clicea
[B]With the exception of Texas, everyone chiming in is from Alberta or some other cold region where it actually snows. They know nothing of serious heat.
Seeing as I was the only one from Alberta that responded I guess that was directed at me. Just to clearify it a bit. In the last 6 years I have spent 2 summers in Houston, 1 in Brownsville TX, 1 California, 1 in Barbados and 1 in Dallas. Last time I checked they got some pretty serious heat in those parts. If you want to know about the cold too. I've spent plenty of time up above the arctic circle in January and Febuary.
Similar Threads for: How do ride with the heat?
The heat is on MotoMan General Discussion 26 08-02-2006 11:07 AM
Bubba goes down in Heat 2 scooter842 General Discussion 8 05-08-2005 09:53 AM
Another way to beat the heat. LoKi Fitness, Training, & Recovery 11 09-03-2004 09:48 PM
01 yz250 heat problems spdfrek 2-Stroke Motorcycles - Yamaha 8 07-14-2004 03:10 PM
straightening bent lever heat/no heat? hondageek General Discussion 15 03-02-2004 02:36 PM
