Ankle supportThis is a discussion on Ankle support within the Fitness, Training, & Recovery forum, part of the Miscellaneous Forums category; I did a search for ankle support here and found a little info about boots. But no brace info.
Does ... |
| I did a search for ankle support here and found a little info about boots. But no brace info. Does any one here use a brace under their mx boots? Or is there a boot that out shines all others for ankle support so you don't need to use a brace. This is for my husband who has injured his ankle numerous times riding. Not a twist, but from his foot over extending upward. We have decided he needs more protection but its hard to find where to best lay down the $. Boot or brace? Both? Any suggestions on brands? Thanks |
| What boots is he running now? Bates wears a lace up type brace under his boots for this exact reason. I had surgery on my ankle due to this exact thing too, although, mine was caused initially from playing a lot of basketball in my youth. MX just gave it that final nudge to get it fixed. Now honestly, Gaerne SG10's would help. The new Scott Genius would also (spendy, but more than likely well worth it). I have A-Star Tech-8's and they BLOW in this area. The other thing he needs to do is practice moving his feet around so that when he lands, he's not on the balls of his feet. It is actually taught that you should have them there so they can help with the suspension, but SCREW that. I've hurt my ankles 100 too many times following that advise. Instead I try and place my foot closer to the middle so there isn't as much leverage to break my foot off. I hope that helps -- Also, the type of brace that my buddy bates wears are really the only kind I can think of that would really fit under the boot. |
| Whats bump mean?? I always see that in other threads Well you could just buy 500$ boots...or you could just buy the buy the 25$ ankle brace made by sixsixone btw the ankle brace i mentioned does not interfere with boot fit |
| Good grief, have some patience. Everyone's still out riding |
| Hey, my man leaves for work Monday night and we need to get this settled before he leaves. dirtbikeboy... Bump means I am posting to push my post to the top of the list In the portal where each new post goes to the top. Basically trying to be seen... but you have to pay a fee and have over 1000 posts for this feature to work, so you really shouldn't worry about it now. Thanks for the tips all... they are good |
| Having 2 bad ankles from football and soccer I twist and sprain my ankles just walking down the sidewalk or in grassy fields. Ive always worn ankles braces with my boots. Even landing hard would cause my ankles to hurt. Side note...for big jumps with hard landings DONT stand on the balls of your feet, but towards the center to heal area. Anyways, about 2 years ago I purchased Oxtar boots and havent had to wear my braces since. Ive overshot 50 ft tables and I could feel my ankles extending without any pain Id look into Oxtars, Sidis Gaernes or the new Scoots-def worth th.e money! |
he is running something that cost around $150. I don't know brand, he doesn't either and they are far away right now for us to go look. Ok so out of the ones mentioned above Doc you wear these Oxtars you say they work well...do they stiffen the up down motion of the foot and side to side? Woody have you worn any boots that helped stiffen the up down motion? |
| I'm watching this too since I broke my ankle a coupl of weeks ago. I was going to go with Gearne but will watch this thread for updates. |
| Hey Keeto..... I don't know if I missed it somewhere else.. bu I was wondering exactly how you fell when you broke your ankle. I know it doesn't take much huh? Not to make you relive it ( |
| Here you go Jen. I just posted the update in the general thread. It has the cause in the thread but I still do not know what caused the crash. I just started swapping and couldn't get it under control and it dug in and tossed me over the bars - I just landed on it wrong. I'm not sure if a better pair of boots would have prevented this but it may have kept my ankle from rolling under like it did. St. Jo Ride Report. |
| Thanks for posting that. I was wondering it your ankle got caught up in the bike or what. |
| I would look into the top end Sidi's also. When I worked at the Honda store the Sidi Rep gave me a nice demo on that very thing w/ those boots... They are top notch in that very area. I would try them on first though as they tend to run a bit narrow.. |
| Cool thanks for the input!!! |
| mxmama, 1st off get him some REAL boots. 2nd, that ankle brace is the exact one I wore after my ankle surgery. It works well. I couldn't get my boot on over the top of it, but if you bought the boot that would fit over it, it would more than likely work. |
| Interesting Woody! I'll have to check into it once I am released to ride again. I'm sure my ankle will be weak but the good thing is, they screwed it back on GOOD! I'll just bend or strip a screw before I break that ankle again! |
#18
| ha ha, I'm sure you'll probably get one of those from your doc. That's where I got mine from. They work really well. Also, let me note, the boots I was wearing were Tech-8's and I wanted to wear the bootie, so they didn't fit. don't wear the bootie and they would have been fine. |
#19
Im all confrused!! is the "bootie" the "brace"? So if you couldn't fit your boot on all the way, how did you wear the brace when you rode? |
#20
| When it comes to the Oxtars & Sidis What models are the ones I need to look at? We will get the brace and the boots I think I need a good pair of boots now too |
| Ankle report | Keetoman393 | Fitness, Training, & Recovery | 39 | 08-10-2007 10:22 AM |
| Leg/Ankle Update | MotoMan | General Discussion | 42 | 11-15-2006 12:06 AM |
| Can you take a look at my ankle? | Woody_YZF | Fitness, Training, & Recovery | 44 | 11-17-2005 07:55 PM |
| BEST BOOTS FOR ANKLE SUPPORT?? | CREEKSIDEMX | General Discussion | 2 | 10-11-2004 07:34 AM |
| Ankle in a cast. | KLRay | General Discussion | 9 | 03-07-2004 07:41 AM |
