Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums
Old 07-11-2018, 02:33 PM
Last Online: Today 06:46 AM
A plugged up or restricted exhaust will also do the same thing.
Old 07-14-2018, 12:35 AM
Last Online: 02-23-2019 11:23 PM
I changed the valves to proX stainless valves and springs. Would it be ok to reuse the stock cotters on the stainless valves? Thanks
Old 07-14-2018, 05:57 AM
No.....If you are speaking of the keepers.
Did you have the valve seats cut or replaced?
Old 07-14-2018, 07:14 AM
wFo250's Avatar
will fall over
Last Online: Today 07:33 AM
You need to get a manual. It will tell you the specs your need. Says to press the valve in place with Prussian blue and measure the contact, you can also pour solvent in the ports and check for leaks that way but it won’t give you a width or height. I used come copper coat gasket spray instead of the chalk just because I had some on hand and it worked pretty well. Spray the valve face and drop it in and measure. Perhaps you have spark and you just can’t see it? Or aren’t properly grounding the plug? I would not have put steel valves in there, but it’s your bike..
Similar Threads for: 2007 yz450 stopped working.
2007 yz450 5 gear problems tundrabeagle3 4-Stroke Dirt Bikes - Yamaha 7 11-20-2014 04:44 AM
2007 yz450 leaks oil tundrabeagle3 4-Stroke Dirt Bikes - Yamaha 2 07-29-2014 09:04 PM
CR250 07 Fork rebound stopped working MrPilipsi 2-Stroke Dirt Bikes - Honda 0 04-28-2013 11:36 PM
bike stopped at mid rev! HELP!!! ridered88 2-Stroke Dirt Bikes - Honda 7 10-14-2008 12:32 PM
KTM250rm393 stopped by cpl mondays ago cr-manp4l General Discussion 3 04-23-2005 12:33 AM
