Old 04-21-2007, 08:32 AM
stfaulk89's Avatar
Last Online: 12-08-2008 05:18 PM
Default Yz250f fork problems
Ok, before I say anything I know there is a post like this one, but my problem is a bit different..
Since I have bought this bike, my front forks seemed to be realy stiff when riding over anything rough it would seem like they would not compress, and toss the wheel left or right to get over the obstacle. I thought it might have just been me for a while under I rode other bikes.. I notice that it is realy soft and keeps a straight path...
So I was seeing if my forks would compress at all riding down the street and putting my front brake on.. they went down an 1inch at the most and stopped... I got my dads friend to try it, same thing, and he knows then he knows something is wrong with it because he knows alot about the subject.
I want to know if I can help this problem any way before I change my fork oil.. and does any of the clamps do anything to help this?
Old 04-21-2007, 08:36 AM
Florida 393's Avatar
Semper Fidelis
Usflag Re: Yz250f fork problems
Stanton,
It sounds like your forks are twisted in the triple clamps. Get them straight and check the travel then. You will have to loosen the fasteners from the clamps all the way down to the axle pinch bolts. Let us know if this helps.
BTW, do you know for sure the oil level isn't too full?
Bill
Old 04-21-2007, 08:39 AM
stfaulk89's Avatar
Default Re: Yz250f fork problems
Thanks Bill, I wasn't too sure about the clamps and I knew somewhere here could help out, I'll let you know how it does
And, I am not sure about my oil level height
Old 04-23-2007, 06:16 PM
stfaulk89's Avatar
It didnt make a difference, im going to take out some fork oil, and easy way to doing this?
Old 04-23-2007, 06:26 PM
The Baron's Avatar
The forks being twisted in the clamps won't cause a bind as the lower fork legs can turn in the uppers. What would cause a bind is if the axle isn't centered in the two lower forks.
1. Loosen the axle nut and then loosen the axle pinch bolts on the lower fork bosses.
2. While holding the front brake, bounce the fron end up and down to make sure everything find it's place.
3. Tighten the left side axle pinch bolts, then the axle nut, then the right side pinch bolts.
Everyone has their own technique but this should unbind the forks if they are in fact bound up. If it were me, I would most likely pull the forks all the way out of the clamps, pull the clamps off the frame and then reassemble after greasing everything just to be sure. There is a possibility that one of your clamps are tweaked and/or the clamp pinch bolts were over-tightened at some point thus pinching the fork tubes and causing a bind inside.
Old 04-23-2007, 06:40 PM
stfaulk89's Avatar
Thanks baron, I will try that next, any other things I should try?
Old 04-23-2007, 08:27 PM
If the forks seem to bind and stick down, I would say bill and baron have you on the right track.
DONT just start pumping oil out. To see if you have full movement, remove the caps (with the bike on a stand so the front wheel is suspended) take the caps off the rods, and then remove the springs,,,slide the forks up and down. See if they are catching. Measure the oil from the top when the springs are out and the suspension is compressed. Don't be a "butcher".
Old 05-03-2007, 08:09 PM
stfaulk89's Avatar
Ok, I made sure they were not sticking, they are not..
today I took my front forks completely off, but my two bottom nuts were stuck on their too damn tight, I could not get them off, neither could my dad.. so I grinded them off.. but once if got my front wheel off and all the clamps un done i took the fork off and just to see how it did, and sure enough it went down all the way, and was soft for me.. is this a sign that everything was too tight? because some of the bolts on my clamps were tight as hell too..
If anyone can fill me in I'll appreciate it.. asked here before I went ahead and drained my oil
Similar Threads for: Yz250f fork problems
Fork Problems 93 KX frame up 2-Stroke Dirt Bikes - Kawasaki 0 06-08-2008 05:57 PM
Fork oil question ?( 2004 YZ250F) YFZQUIN Dirt Bike Suspension Tuning 3 03-23-2008 01:19 AM
'04 YZ250F fork seal replacemnt..Help!! ScottyJFZ1 Dirt Bike Suspension Tuning 3 11-02-2007 10:34 PM
Wanted .44 Fork springs YZ250F Yamahax22 Classified Ads 0 03-31-2005 07:45 PM
YZ250F Fork rebuild VET393 4-Stroke Dirt Bikes - Yamaha 5 03-07-2005 05:45 PM
