YZ 125 Rear SupensionThis is a discussion on YZ 125 Rear Supension within the Motorcycle Suspension Tuning forum, part of the Dirt Bike - ATV - Suspension Forums category; I just got this bike traded my 07 CRF150R for it, and wow this 125 was full of problems that ... |
| I just got this bike traded my 07 CRF150R for it, and wow this 125 was full of problems that I didnt notice until now. But heres something new, the rear shock was shot so I was like well I'll just buy this 2001 yz 125 shock off of ebay well turns out the shock is form a older bike like a 94 and the rebound compartment(part where shock connects to linkage aluminum piece connected to the rod I dont know the name) is shorter on the 94 so what I need to know is, is there anyway to swap this piece from my 05 onto the 94? Oil goes into the rebound adjuster (right?) so would it be possible since the oil is pressurized? (Is it possible without taking the whole shock apart, is what I'm asking.) |
| There is no oil in that lower area, but pulling it apart if it is charged with nitrogen will likely create an undesired result. The rebound adjustment is transfered to the valving via a small shaft through the center of the main shock shaft and is sealed, so if the shock has a nitrogen charge, it could push this rod out and expell oil when the bottom is removed. Discharge the shock if you are going to try this. I can't say if the older lower housing will work or not - sounds like something I would not try. I would try to locate the correct shock or simply rebuild what you have. It's not all that tough to rebuild a shock if the shaft and housings are good. Scott |
| Well I know how to rebuild the old one its just that I like in a small town and there's no one who has nitrogen with in an hour drive so I just dont want to discharge the shock... |
| Please do not dismantle a charged shock! Scott |
| I'm not going to, I am just going to leave it how it is |
| Chances are your 05 shock is in better shape than the older one. You say the shock is toast - what's up with it? Does it leak oil? Scott |
| Yes it leaked oil pretty bad and when ever I compressed the shock really fast and let it come back up it would make a metal hitting metal noise.. |
| That 05 shock is a lot better than the 94. The valving is better, too. I strongly suggest getting the 05 shock rebuilt. Scott |
| I know its better I just dont have the money to rebuild it right now. |
| 93 kx 250 rear shock | jmac88 | Motorcycle Suspension Tuning | 3 | 12-26-2008 10:41 PM |
| supension setting question?? | trailrider894 | ATV/UTV - Honda | 7 | 03-28-2008 11:41 AM |
| 500 rear tire | mxer727 | 2-Stroke Motorcycles - Honda | 7 | 12-09-2004 01:30 AM |
| How many rear teeth do you run? | brcrk | General Discussion | 5 | 03-13-2004 01:17 PM |
| Supension Price? | Racer#857 | Motorcycle Suspension Tuning | 3 | 11-16-2003 07:28 PM |
