What the fork is wrong?This is a discussion on What the fork is wrong? within the Motorcycle Suspension Tuning forum, part of the Dirt Bike - ATV - Suspension Forums category; I'm reassembling a set of Showas from a friend's '00 CR250 after a respring and fluid/seal change. I've done this ... |
| I'm reassembling a set of Showas from a friend's '00 CR250 after a respring and fluid/seal change. I've done this one other time so I'm not totally green. First one went together like clockwork. The second one, not so much. As I start to screw the center bolt onto the damper rod (?) it starts clicking as if I'm adjusting the rebound dampening. After messing around with it a bit I realize that the push rod is not turning freely inside the damper rod, hence the clicking of the clicker. Any ideas why or how to get it to work correctly?????? |
| Whew!! Got it figured out but I couldn't have done it without all of the helpful advise! |
| If you don't mind, perhaps post up how you did it in case others might have the same problem in the future!! Glad you got it working man! |
| Right side fork really bouncy after changing my fork seals. | jrhockey03 | Motorcycle Suspension Tuning | 2 | 05-07-2009 06:31 AM |
| fork gone wrong after new seals help??? | gtb868 | 2-Stroke Motorcycles - Honda | 10 | 05-01-2009 12:01 PM |
| pouring fork oil,wrong adjustments | chopshopinc | Motorcycle Suspension Tuning | 4 | 04-29-2009 10:43 AM |
| 2003 kx 250 fork oil and fork seal service | wera917 | Motorcycle Suspension Tuning | 4 | 02-04-2007 09:26 PM |
| 01 CR250 fork protector rubbing on fork tube | AustoUS | 2-Stroke Motorcycles - Honda | 15 | 08-26-2006 03:30 PM |
