Old 03-21-2005, 12:52 AM
KKXR400R's Avatar
Default tripple clamp offset
A while ago i was talking to a fellow rider about tripple clamp offsets. Without looking stupid I did the whole " smile and knod" thing Yet, I'm still confused. What is the advantage of changing the offset? I have no clue what this does...anyone willing to respond would be helpful.
thanks in advance
Old 03-21-2005, 01:19 AM
AaronRider's Avatar
Last Online: 01-15-2013 02:17 AM
Default Re: tripple clamp offset
If you change the triple clamp offset, it will point the forks either closer or farther from the bike, which will change the handling characteristics. For example, changing the offset may make a bike turn quicker.
Old 03-22-2005, 05:37 PM
Age is a state of Mind
I don't know the exacts either, however, my '03 CRF comes stock with 24mm offset T-clamps. If you change them to 22mm or 20mm the bike will turn better at the cost of some high speed stability. Basically, it changes the distance from the center of the crank to the center of the mounting bolt for the front tire. 20mm vs 24mm - 20 mm would mean the front wheel is closer to the bike.
Old 03-22-2005, 05:51 PM
AaronRider's Avatar
Anyone know how they measure the offset?
Old 03-22-2005, 06:26 PM
mtk's Avatar
mtk mtk is offline
Changing triple clamp offset changes the trail of the bike, which affects handling. Trail affects the self-centering behavior of the front end. More makes it more stable, at the expense of turning quickness. Like most things, it's a trade off/balancing act.
Offset is measured from the center line of the steering stem to the center line of the fork axes.
A good book on the subject is Motorcycle Chassis Design by Toany Foale and Vic Willoughby.
Old 03-23-2005, 01:51 AM
Kenny400's Avatar
Last Online: 09-17-2014 12:02 PM
So would you say trail is like degree of caster on a car/truck?
Similar Threads for: tripple clamp offset
offset KXf 450 fastbike 4-Stroke Dirt Bikes - Kawasaki 0 02-27-2007 04:37 PM
WANTED: rubber mount tripple clamp to fit 01 cr250 pimp559 Classified Ads 4 12-31-2005 10:27 PM
Wanted: Upper Tripple Clamp and Bars for 250F McCracken21 Classified Ads 3 02-06-2005 04:58 PM
Tripple Clamp reborn_450 4-Stroke Dirt Bikes - Honda 15 11-14-2003 09:08 PM
Anyone want some applied tripple clamp? madcow393 General Discussion 6 10-04-2003 03:33 PM
