Old 08-09-2007, 09:38 PM
misfitsbob's Avatar
Last Online: 10-05-2011 02:24 PM
Default taking my yz125 forks apart
its an 02 and ive never changed fork seals before...i know how to change springs and all that but ive never taken a fork completely apart so i cant get to the seals...anyone got a how to on it?
Old 08-09-2007, 11:03 PM
brokenbones's Avatar
Last Online: 06-24-2019 09:40 AM
Default Re: taking my yz125 forks apart
If they are the same (or similar) to my 01 yz250 forks then you will need a special tool to do the job. I made one out of an old jack handle, rocky mountain used to sell them for $70.
Old 08-09-2007, 11:59 PM
misfitsbob's Avatar
got any pics of what the tool looks like? or the one you made?
Old 08-10-2007, 03:25 AM
Last Online: 04-21-2010 10:19 AM
Cool Re: taking my yz125 forks apart
it is pretty straight foward to strip the fork (i did on my 02 yz125 before)
job will be easier if you got a air wrench, if not it doesn't matter, just need abit of luck and more energy
with the fork out of triple clamp, before you start any work, back out all compression and rebound clicker, make a note and count them.
1. loosen fork cap, loosen the jam nut and fork cap can be taken out, and you can remove at this juncture, and collaspe the fork tube
2. pour out all the fork oil into a container
3. with the air wrench, and correct size allen (a quality type), spin out the base valve out from under the fork leg, base valve should spin out relatively easy
4. with the base valve out, the cartridge can be pull out of the fork
5. now, you can start to split the fork tube
6. pry open the duct cover with a large screw driver
7. use a small screw driver to remove the clip inside
8. with the clip remove, hold the fork tube, 1 hand on the chrome part, 1 hand on the other fork tube, with a swift jerk action, pull apart the fork tube
9. from here, you can seethe seal, 2nos teflon coated bushing, remove them
10. with the correct order, slip the duct cover down the chrome tube, follow by clip, seal (before it can cut the seal), the outer bushing, and lastly the inner bushing
11. slip the chrome tube into the other fork leg, let the inner bushing in and then the outer bushing, use a fork seal rammer to knock it lightly into the fork tube, it should seat it easily
12. now, use the fork seal rammer and seat the seal in snugly (not to much strength), just make sure it seat down squarely
13. put back the clip, and duct cover (you can use the seal rammer)
14. now you are done, with seal replacement
15. collaspe the fork tube, make sure the fork tube are sliding in and out effortlessly
16. then slid back in the cartridge, and use ya hand to screw back the base valve slowly, when it is hadn tight, use the air wrench to tighten it, and then a torque wrench to it suggested torque number
17. now, pour in ya favourite fork oil and bleed it properly (this is important)
18. with the correct oil height, slip in the fork spring and install the fork cap
19. set all clickers back to original setting and you are ready to go.
hope this helps.
Old 08-10-2007, 11:05 AM
misfitsbob's Avatar
yea that helps thanks
Old 08-10-2007, 11:15 AM
Bob,
I am glad someone else wrote all that out for you. Two things you may encounter: If you don't have an air wrench I loosen the allen head when the fork is still on the bike. Just crack it loose at that point. I can get them loose by hand easier if there is some spring load on the tubes. Sometimes lots of spring load via a tie down strap.
Second is the "jerk". Sometimes it takes a whole lot of that action to get the forks apart. You are actually pulling the bushings out as you do this. It takes more force sometimes than you think it should, but is is the only way to get them apart.
You can make some useable drivers from PVC pipe, or better those PCV pipe connectors that glue on. A blade, a file, a heat gun, you can get them to fit. (hose clamps too).
Old 08-10-2007, 11:05 PM
oh ya, i left out the "if ya do not have the air wrench part"
what i do is, clamp the fork leg onto a aluminium vice firmly
with 1 hand pulling down (compressing) the fork, the other hand, loosen the basevalve.
it will be easier if ya got a buddy with ya.
Old 08-11-2007, 05:35 AM
misfitsbob's Avatar
me and a friend of mine changed mine and his last night...wasnt no where near as hard as i thought it would be...we didnt have a seal driver but we still go them in there...it would have been easier with one tho.
Old 08-11-2007, 11:56 AM
Headbanger's Avatar
Last Online: 05-06-2008 08:34 PM
I think all the guy wants to do is change the seals in his forks. Why are many of you steering him into special tools and a complete rebuild like removing the base valve?
YOU DO NOT HAVE TO GO THIS FAR TO REPLACE SEALS!!!
The only tools he needs are a couple wrenches, a small screwdriver or pick to remove the internal snap ring found under the dust seal, and a seal driver which can be made from a piece of PVC pipe. A seal sleeve helps but can be done without.
Simply tear the forks down, per the manual, only until you have the two sections apart. DONT GO ANY FURTHER! Everything can be done from there. Then find a piece of PVC pipe that will fit over the inner tube and inside the outer tube. Cut it about two or so inches long and than down each side so you have two halves. Use it do drive the primary seal.
Sorry, but thats all folks. Easy!
Head Banger
Old 08-11-2007, 02:48 PM
misfitsbob's Avatar
Head Banger
yea all i was wanting to do was change seals...got it done last night tho...wasnt near as bad as i thought it would be
Similar Threads for: taking my yz125 forks apart
Are cr125 forks the same as cr250 forks? Beans 2-Stroke Dirt Bikes - Honda 1 04-14-2009 12:09 AM
Adjusting 1999 yz125 forks 2stroke rider7 Dirt Bike Suspension Tuning 5 04-03-2008 03:54 PM
2003 YZ125 many questions. forks and low end power...144cc??? Devin313 2-Stroke Dirt Bikes - Yamaha 20 10-15-2007 11:52 AM
Taking a sig request... Z-Man 393 Photo & Video 4 08-01-2004 12:24 AM
