Old 03-06-2008, 11:09 AM
kawamama3's Avatar
Last Online: 05-01-2010 06:14 PM
Default Suspension for a kx250f
I have a kx250f '07. I have never messed with the stock suspension on my bike. I have been riding it for 10 mo. and I am really comfortable on my bike. However, now I am wanting to tweak things to make my bike better for me. I think messing with the suspension would help the way my bike responds to corners and landings. This is my first bike but I am pretty sure things need to be tweaked maybe a little softer set up. I come pretty close to the weight requirements being 130lbs 5'6 girl. Any advice on improving a stock suspension?
Old 03-06-2008, 11:21 AM
pjg351's Avatar
Last Online: 09-18-2013 12:01 AM
Default Re: Suspension for a kx250f
You'r probably a touch to light for the stock springs, the right spring rates will make a differance. Did you try and set the sag properly?
Old 03-06-2008, 11:37 AM
kawamama3's Avatar
I havent touched anything on the bike yet.
Old 03-06-2008, 11:46 AM
char393's Avatar
cha cha
You should really get the sag set. From there you can start to make adjustments with the clickers.
I was looking for a link that describes the process... I'll keep looking and post it up.
Old 03-06-2008, 11:50 AM
char393's Avatar
cha cha
Well, it's from ThumperTalk, but maybe this'll help:
Set Your Sag - ThumperTalk
Old 03-06-2008, 11:55 AM
kawamama3's Avatar
Talking Re: Suspension for a kx250f
Thanks! I will check it out now. Really needed the direction on where to go first. Nice pic
Old 03-07-2008, 05:10 AM
Age is a state of Mind
I have to agree with pjg, I think you are a bit light for the springs.
Do as Char recommends and get the sag set (even if she can't search ), and then go from there. I'm sure your static sag will be more than 25mm by a bit. Which means you need lighter springs.
Once you get that set (it helps with turning a TON), we can work on the clickers and some edumacation about what they all do. You'll also need to decide what you don't like about the current setup.
Here is what I found from mx-tech.com
Stock Spring Rates:
Fork: 0.45 kg/mm
Shock: 5.3 kg/mm
Recommended Spring Rates:
Fork: 0.39 kg/mm
Shock: 4.7 kg/mm
So they think you need lighter springs too.
Old 03-22-2008, 08:13 PM
Last Online: 03-23-2008 11:58 AM
well if you need suspension work done let me know my buddy brian owns his own suspension company and i can get the work done for you
Similar Threads for: Suspension for a kx250f
KX250F VS all others Charles4x4 4-Stroke Dirt Bike Bike Forums 29 10-28-2012 01:45 PM
does anyone have a 08 kx250f jordan_pense 4-Stroke Dirt Bikes - Kawasaki 4 10-09-2007 05:46 AM
KX250F joe346CBMX 4-Stroke Dirt Bike Bike Forums 4 08-31-2007 10:22 PM
KX250F at GMB II cowboyona426 4-Stroke Dirt Bikes - Kawasaki 9 10-27-2003 09:50 AM
kx250f! yaka 4-Stroke Dirt Bikes - Kawasaki 4 08-18-2003 12:51 PM
