Old 01-27-2004, 11:19 PM
Last Online: 05-23-2004 08:18 PM
Default Suspension Help Needed
HONDA CR250 2001. I recently maintenanced the forks and seals and upon reinstallation I noticed that the rebound clicker on one of the forks won't dial all the way in to the full position. It continues to turn without ever stopping. I set the rebound by turning 7 clicks from "out" rather than "in". What' s causing this?
Old 01-28-2004, 10:49 AM
Faded's Avatar
Last Online: 09-21-2018 05:15 PM
Default Re: Suspension Help Needed
How many clicks out did you go before you realized it wouldn't stop? I can go 22 which seems like it takes forever... I'd dissasemble and check the rod that runs from the rebound clicker up to the rebound valve stack and make sure it's in good condition. I'd also make sure that you properly tightened the retaining nut on the shaft against the rebound clicker assembly. Make sure to check for proper operation before reassembly.
Old 01-28-2004, 01:19 PM
Mecrazyperson's Avatar
Banned
Last Online: 05-12-2008 03:26 PM
Andrew to the rescue. How did those reeds work on your bike?
Old 01-28-2004, 02:15 PM
Blitz393's Avatar
moved to the suspension forum
i have absolutely no experience with Showa / CR forks so i cant answer your question. faded seems to know though
Rob
Old 01-28-2004, 02:19 PM
Faded's Avatar
Thanks Rob,
Wish I could just move stuff around, you make it look so easy!
Similar Threads for: Suspension Help Needed
'78 Maico 400 Suspension Needed CorbanTek Vintage Riding 7 07-25-2008 12:19 PM
A little HELP is needed! valverde General Discussion 24 01-28-2006 07:57 AM
cr85 suspension help needed CR85MXR 2-Stroke Dirt Bikes - Honda 3 11-08-2004 10:58 PM
CR Suspension help needed Deak Dirt Bike Suspension Tuning 10 09-24-2003 10:41 PM
NEEDED!!!!! KSmotoXrider15 Classified Ads 3 05-02-2003 09:31 AM
