Old 02-11-2004, 04:59 PM
Last Online: 12-31-2007 11:20 AM
Default success on fork oil change?
I have an 03 crf 450 that is do for fork oil change. My seals are not leaking. Do your seals hold up to the teardown and reassembly? If the success is low, I will replace the seals. I weigh 175lbs. What weight work best? My ability is upper intermediate. Any help would be appreciated. BERM!!!
Old 02-11-2004, 05:20 PM
Faded's Avatar
Last Online: 06-19-2018 08:23 AM
Default Re: success on fork oil change?
You'll be safe. I've had the same seals in mine for two years now and I've had the forks apart a few times. If you pull the seals off the slider just be very carefull when putting them back on. A little oil and a sandwich baggy go a long way here.
Old 02-11-2004, 07:57 PM
Thank you for your input. Any suggestion on oil weight for my fork oil? Berm!!!!
Old 02-11-2004, 08:00 PM
Age is a state of Mind
I have one. I just put in motorex Racing 5wt fork oil and I love it.
Noticable difference. About $11 a bottle and you'll need 2 if you are doing the inner and outter chamber.
PS. Props to Faded since he's the one that changed the oil for me in mine, and he's the one that told me how much I would need.
Old 02-11-2004, 08:47 PM
Did you use stock quantity for the outer chamber? Is there a min and max for quantity for the outer chamber>
Old 02-11-2004, 11:14 PM
I don't recall what stock is, but I went with 390cc's.
The range is something like 360 - 412cc's
Old 02-12-2004, 09:55 AM
Faded's Avatar
Looks like Woody_C has taken care of you.
Old 02-12-2004, 10:04 AM
KTM250rm393's Avatar
Another good fork oil is Mobil-1 ATF Synthetic. Shocknut turned me onto this. It runs about $5.50 a quart and is found at Auto Zone.
Old 02-12-2004, 04:30 PM
The only catch to this fluid is it runs thick. I think he said they were figuring it to be anywhere from 7wt to 10wt.
Old 02-13-2004, 08:52 PM
Last Online: 02-03-2009 03:21 PM
I did some research lately on the subject, and for twin chambers the hot setup is: Motorex 2.5w inner chamber, and M1 ATF(15w) in spring chamber.
Old 02-13-2004, 09:06 PM
Hmm.. that's interesting. Are you going to go that route?
If you do, let us know how it goes and what you think.
Old 02-14-2004, 09:16 AM
THANK YOU GUYS FOR ALL OF YOUR REPLIES. DOES ANY ONE KNOW WHAT HONDA USES FOR THE STOCK OIL IN THE FORKS? THE STOCK FORKS WORKED SO GOOD IT COULD ONLY GET BETTER. BERM!!!!!
Old 02-14-2004, 01:33 PM
Me?
I sure am gonna try it.
First the M1 Atf is a little bit thick to run in the IC. It has some very good qualities though; like the ability to stay clean and prevent internal wear-exactly what you want in the spring chamber.
For the Inner chamber I was recommended to use Motorex 2.5 because their products are a litle bit thicker than most other in the industry. People who are used to Motorex thicker viscosities usually put the 2.5w in Showa IC and the 5w in Kayabas
It would be hard for me to give a ride report soon. I'll be happy to report what I think of this setup this spring. There is snow everywhere 3' high. Right now I'm riding my sled to survive winter : .
Take care.
J-S
Old 02-14-2004, 01:42 PM
Honda / showa SS7 oil. part # is 08208-0005 It is sold per 500ml
I have heard of less than stellar reviews of Honda suspension oils.
Old 02-14-2004, 06:33 PM
Dell30rb's Avatar
I wouldnt recommend the ss7 to anybody (except the guys I race against...).
I use the HP 5w fork oil and it is a good fluid at a reasonable price. I tried some ss 5 in my shock and it was trash...
Similar Threads for: success on fork oil change?
98 RM250 Fork Seal Change stu35 Dirt Bike Suspension Tuning 11 12-06-2007 05:45 AM
Fork oil change 98 RM 250 munster Dirt Bike Suspension Tuning 7 11-30-2005 06:25 PM
95 kx250 fork seal change jshaw2628 Dirt Bike Suspension Tuning 12 02-23-2004 01:47 AM
PW80 fork oil change kennym26 Dirt Bike Suspension Tuning 12 11-20-2003 03:57 PM
spring change a success!!!! reborn_450 Dirt Bike Suspension Tuning 16 10-02-2003 06:50 AM
