Old 03-05-2014, 07:47 AM
Randog Leader's Avatar
Default Steering Stem Bearing Installation
I have new steering stem bearings and have removed the bearing from the triple tree and now need to install the new one. There is a tool that you can order that will fit around the stem and only touch the inner race of the new bearing as you press or smack it into position. The cheapest ones are about $60.
Has anyone found a certain sized pipe that will accomplish the same goal?
Old 03-05-2014, 11:57 AM
Last Online: Today 01:59 PM
I'm pretty sure either one of those can help you solve your problem
Old 03-05-2014, 12:28 PM
stevo450's Avatar
Lol!!!
Well I have heated the bearing slightly ( preferably without a blow torch ) and it slide right on....the seal was fine using this method ...
Or just go to your local hardware ( bigger one ) with the bearing and triple tree, size them against a decently thick pipe
Old 03-05-2014, 01:38 PM
I was for sure going to freeze the triple tree and heat the bearing. I have measured the dimensions and they are no where near the standard pipe sizes. Hopefully, I can find something at the hardware store that will work.
I was just checking to see if anyone had done this and knew of an exact sized pipe that worked. I'll post it if I figure it out.
Old 03-05-2014, 02:01 PM
stevo450's Avatar
Shouldn't need it if your fast and careful with the heat method
Old 03-05-2014, 04:07 PM
Last Online: 01-14-2019 08:04 PM
Default bearing driver
I use the old bearing for driving the new, cut a slot through the old bearing this becomes your sacrificial driver now use a pipe does not matter if its not the exact size as you are hitting the old bearing which is the exact size of new one the slot you cut makes the old bearing easy to remove. This works great on the races inside the steering neck
Old 03-06-2014, 08:16 AM
That's a good idea, too. I do that on a lot of things but thought that it might get "stuck" at the bottom. I guess that is what the slot is for?
I found the perfect fit for anyone who is interested. It's the top rail pipe on chain link fence. It fits perfectly around the steering stem and only touches the inner race of the bearing.
Note: Do not get caught sawing your neighbor's fence. Do it at night, if at all possible.
Old 03-06-2014, 08:34 AM
1276brady's Avatar
Last Online: 10-17-2017 08:51 AM
Quick and quiet, like a ninja!
Old 03-06-2014, 09:51 AM
Yep that's why the slot is cut
Old 05-25-2014, 12:55 AM
Last Online: 08-11-2014 10:20 PM
I just did mine ... I put the race in the freezer I warmed up my frame and used A socket to tap into place can't remember what size it was but it went together beautifully
Similar Threads for: Steering Stem Bearing Installation
Steering stem bearing replacement Help rm 125 burtonbutt1 2-Stroke Dirt Bike Forums 2 07-13-2008 10:22 AM
Steering stem bearing installation? AKColby 2-Stroke Dirt Bikes - Honda 5 12-21-2005 09:33 PM
Main bearing installation SirFallsALot243 General Discussion 12 07-08-2005 09:20 AM
YFZ 450 steering stem ? smash metal ATV/UTV - Yamaha 35 04-13-2005 09:45 AM
Steering Stem reborn_450 General Discussion 9 12-08-2003 03:59 PM
