Old 01-06-2004, 11:05 AM
drman's Avatar
Default Re: Rear Shock Tear Down
Ok, how do I get the bushing out?
Old 01-06-2004, 01:06 PM
suspension nut's Avatar
Last Online: 12-24-2006 05:17 PM
You can replace the complete sealhead for around $45.00. that way you get the bushing wiper and shaft seal which should be replaced anyway.
Russ
Old 01-06-2004, 03:16 PM
drman's Avatar
I am getting the seal already I think...I ordered Race-Tech parts---Oil and Dust seals and the bushing.
Old 01-08-2004, 10:19 PM
Shocknut's Avatar
To rebuild your sealhead you have to take it all apart. You can pull the top out bumper out of it by pushing a fairly wide flat blade screw driver under it and twisting it and prying it up. Or you can grab it with a needle nose and pull it out.
Then remove your seal plate, seal and pry the dust cover off the top. Then you can get in there and press your bushing out from the top down.
Old 01-09-2004, 03:45 PM
Shocknut's Avatar
Originally posted by Woody_CRF
Hey shocknut, what exactly is that screw for?
I knew I missed something on this thread.
Anyway, that screw is there to hold your rebound adjuster in so to speak. If you were to ever pull one out you'd understand whats going on in there. The whole assembly can be removed if need be. Sometimes you get one thats a little stickey and you can clean them up during the tear down process even without removing the assembly.
There is also a hex (allen head) screw on the side of the clevis. You can remove that and there will be a small spring and ball bearing behind it. That is your detent for the adjuster so it clicks into position. If you remomve these things and spray out with some brake cleaner and compressed air then shoot some WD 40 (or equivalent, I use Mobil Synthetic Spray Lube) in those holes you can work that adjuster so it frees up and spins nice. Just don't lose your little ball bearing and spring. I have only had to remove one in all the time I've been working on them and I was still able to get that one to work again. Really, there is no need to remove the screw from the bottom unless you intend to pull the assembly out of the clevis.
Old 01-09-2004, 06:35 PM
MotoMan's Avatar
Last Online: 10-17-2018 02:26 AM
Sweet, thanks for the info Shocknut!
Old 01-10-2004, 03:21 PM
Age is a state of Mind
Last Online: 10-10-2018 11:27 PM
Yes, thanks you.
Old 01-28-2004, 06:49 PM
drman's Avatar
Ok, it's been back together for 2 days...I set my sag and went riding...WOW!!! ALOT better.
Old 01-28-2004, 07:23 PM
Cool, good to hear.
Old 01-28-2004, 07:41 PM
Dell30rb's Avatar
KB?
Old 01-28-2004, 07:46 PM
Yeah, I think so.
Old 01-28-2004, 08:40 PM
Shocknut's Avatar
what is KB?
Old 01-28-2004, 08:41 PM
Knowledge base.
Old 01-29-2004, 08:15 AM
Frakke's Avatar
Last Online: 08-02-2017 04:42 PM
Some great info here!! I get to understand my shock a bit better now!! (for taking it apart I mean!!) Thx Shocknut
Similar Threads for: Rear Shock Tear Down
93 kx 250 rear shock jmac88 Dirt Bike Suspension Tuning 3 12-26-2008 09:41 PM
Rear shock.... 2001hondacr125 General Discussion 0 06-09-2008 07:36 PM
Rear Shock kawaboy22 General Discussion 0 07-16-2007 04:11 PM
Rear Shock Oil?? excelr Dirt Bike Suspension Tuning 3 12-30-2003 11:01 AM
What the... Help with rear shock!! Please! CRacer Dirt Bike Suspension Tuning 7 11-17-2003 08:52 AM
