Old 03-15-2009, 06:28 PM
Last Online: 03-18-2009 10:49 AM
Default pouring fork oil,wrong adjustments
my 93 cr 125 blew the fork seals.i knew it was comming because the top and bottom adjustment screws have no stop.they spin forever in any direction.they were like that when i got it 3 weeks ago and i took it out for a real ride todayand almost instantly went to hell.
what do i need to make them to where i can equally adjust the?
i have the fork seals and manual but i don't know if i need new screws or new pieces inside the forks.
Old 03-15-2009, 06:34 PM
SikspakD's Avatar
Last Online: 02-10-2014 06:30 AM
If you're adjusters turn forever then something is broken inside of the forks. You should have a suspension tech look over the internals, if you are not up to it yourself. They can replace the seals for you as well, oil height is critical on most forks. This is not a easy job, so If you have no idea what you are doing you may risk really botching up the job. You will need an assortment of specialty tools to do this. Good luck
Old 03-15-2009, 07:15 PM
thanks for the info!!i am very mechanically inclined but,this is my first time owning a dirt bike.unfortunately i am unemployed at the moment and can't afford to have someone else do it.i believe i am smart enough not to screw it up.i just don't know the names of all the parts.i am by no means a professional mechanic i am purely self tuoght.to me it's worth trying my self and if i blow the seals again then i'll swallow my pride and let someone else do it.anymore info would be greatly appreciated.thanks!!!
Old 03-15-2009, 08:19 PM
crfjedi393's Avatar
Last Online: 03-31-2015 09:33 PM
There are several vids out there that will give you some good tips. Here are some to get you started. I am sure you can find others by searching.
Old 04-29-2009, 09:43 AM
Duran676's Avatar
Last Online: 08-02-2012 04:12 PM
what would we do with out you tube
Similar Threads for: pouring fork oil,wrong adjustments
fork gone wrong after new seals help??? gtb868 2-Stroke Dirt Bikes - Honda 10 05-01-2009 11:01 AM
carb adjustments merky 2-Stroke Dirt Bikes - Yamaha 5 12-25-2008 09:45 AM
HELP!!!! just rebuilt, tranny oil pouring out at base of cylinder acw592 2-Stroke Dirt Bikes - Suzuki 3 06-06-2008 11:19 AM
250 SXF Valve Adjustments Orange Coyote 4-Stroke Dirt Bikes - KTM 3 07-12-2007 06:23 AM
Valve Adjustments... ALarsh 4-Stroke Dirt Bikes - Honda 4 06-01-2004 07:46 PM
