Old 01-22-2004, 07:31 AM
Last Online: 05-03-2004 09:55 AM
Default KX 80 SAG
My 12 yr old son , 80 pounds just got a 2000 kx 80,need to set the sag. Question is the 100mm setting a good starting point for someone his size ? I thought I read somewhere that with this particular bike that 95 mm was a better starting point, I don't have the owners guide,any assistance would help
Old 01-22-2004, 07:40 AM
suspension nut's Avatar
Last Online: 12-24-2006 05:17 PM
Default Re: KX 80 SAG
Willets,
Between 75mm and 85 for the KX 80............. I believe the kx 85 was between 75 and 95mm
MX---------------------- 80mm
Harescrambles------ 85mm
Russ
Old 01-22-2004, 09:52 AM
Age is a state of Mind
Generally speaking sag should be 1/3rd of total suspension travel.
so as suspension nut said.
Old 01-22-2004, 12:20 PM
Thanks for the info, So If I'm setting his Race sag to 75mm-80mm is his Static sag still going to be at 1 - 1 1/2 inch or will it be smaller also
Old 01-22-2004, 01:40 PM
Dell30rb's Avatar
Static sag should be the correct amount, 80lbs is about the target weight for that bike.
