Old 12-14-2003, 06:52 AM
yzf141's Avatar
Last Online: 12-20-2003 04:59 PM
Default Having a shop adjust or do-it-yourself
Motoman, Shocknut & Ranger: I race a 02 YZF250, I am a 38 year old, 5'6", 160lbs, 1 year racing experience and first dirtbike.
I rode the beginner class all year only jumping singles and tabletops. I am going to move to the novice class or veterans class next year. Finally the question is: Should I pay alot of money to have a shop redo and adjust my suspension or attempt to do it myself? Also will a shop take the time to really explain show me how to adjust and understand the suspension? What would you change on a stock suspension first with my experience(lack of)? Even with my lack of experience I know that a proper suspension gives you more confidence in jumping. Thank You....
Old 12-14-2003, 06:56 AM
Yardpro393's Avatar
Default Re: Having a shop adjust or do-it-yourself
well i could answer your question, but since you left me out then tuff nookie
Old 12-14-2003, 07:02 AM
Yardpro393's Avatar
well i guess i wll anyhow )
do you have your sag set?
setting your race and static sag will determine if you need new springs. a spring swap you can surely do yourself. next would be to set your clickers. this is also a self done job. after that would be a revalve. this should be done by a shop. wether or not you NEED a revalve is arguable. try setting your sag and clickers first.
you know how to do these?
Old 12-14-2003, 07:13 AM
MotoMan's Avatar
Last Online: 10-31-2018 02:40 PM
Yardpro, as always, gives good advise. there are some items you can do yourself to make your bike act alot better.
How much do you weigh? Does your bike have stock springs?
Old 12-14-2003, 07:37 AM
Yardpro393's Avatar
uh, jim,
finish your coffee first. he is 160# (line two of his posts)
the statement that i give good advise, however, is dead on.
BTW, good morning sunshine
Old 12-14-2003, 08:45 AM
MotoMan's Avatar
lol you are right, I was on my first cup of coffee, should never post before finishing it.
You are at the edge of the stock springs, I would think that a step up may be in order, try and set your sag first and if you can achieve the correct amount of race sag and still have the correct amount of static sag then you should be ok.
Old 12-14-2003, 08:50 AM
Yardpro393's Avatar
a local tuner here is putting softer fork springs in almost every 426 he does. he says they come way too stiff stock. anybody else hear anything about this?
Old 12-14-2003, 08:52 AM
YzRacer#53's Avatar
Last Online: 02-15-2006 08:13 PM
Your manual can help you out with that stuff.
Old 12-14-2003, 09:01 AM
MotoMan's Avatar
Right, but he is riding a 250f YP. Better have another cup of coffee.
Old 12-14-2003, 09:02 AM
Dell30rb's Avatar
160 sounds about right for the stock springs. Usually 125 class bikes are made for 145-165 lb riders.
Has the fork and shock fluid ever been changed since the bike was new? If not, change it before you start tuning. Motorex is a good over the counter fluid. Use 5wt in the forks. Also, the fork bushings may need to be replaced (1yr is around their useful life). If the bushings are worn, then your forks will feel harsher on smaller bumps.
Once you get fresh fluid, and fresh bushings/seals if they are worn, then you can start tuning. Start with the race sag at about 95mm and set the clickers to factory positions.
I'll leave you to a tuning guide that has already been written up, but remember that the shock rebound also affects compression to a degree.
Similar Threads for: Having a shop adjust or do-it-yourself
carb adjust vincexxx77 2-Stroke Dirt Bikes - Honda 7 07-26-2007 08:50 PM
KFX 400 Valve adjust help! Tim420 ATV/UTV - Kawasaki 15 09-29-2004 07:40 PM
How do you adjust your chain? char393 General Discussion 12 07-12-2004 11:16 PM
How To Adjust Carb??? 2kHondaCR500R 2-Stroke Dirt Bikes - Honda 11 04-07-2004 08:10 PM
How do I adjust my shocks? BIKERnBLACK9999 Dirt Bike Suspension Tuning 0 03-27-2004 05:31 PM
