Front end bouncing around
This is a discussion on Front end bouncing around within the Motorcycle Suspension Tuning forum, part of the Dirt Bike - ATV - Suspension Forums category; When I'm running wide open and when I hit quick little bumps my front end starts bouncing around from side ...
Old 09-16-2007, 10:28 PM
RoostRM125's Avatar
Last Online: 10-15-2008 09:07 PM
Default Front end bouncing around
When I'm running wide open and when I hit quick little bumps my front end starts bouncing around from side to side and up and down real quick making my tire shake from side to side which is pretty scary running wide open. Now what do I have to adjust on my '94 RM 125 to make the front end not do this and ride smooth, I am 5' 7" and only weigh 135 lbs. Any help would be appreciated.
Old 09-17-2007, 08:00 PM
YZalltheway's Avatar
back up and running
Last Online: 11-05-2009 02:25 PM
Default Re: Front end bouncing around
well first you need to make sure that your sitting forward on the bike, that always helps headshake. I dont know of anything else except for a steering stabilizer, but those are big buck$
Old 09-17-2007, 08:16 PM
Billyboypaints's Avatar
My names Billy And I Paint
Last Online: 12-19-2009 06:41 PM
make sure the forks are set even adjust your clickers and see if that helps
this helped my bike a little maybe someone with more knowledge will help us
Old 09-17-2007, 09:59 PM
Silver_Fox's Avatar
Wut the?
Last Online: Today 10:24 AM
Headshake, it can be very scarey. It bucked me off once and broke my collarbone. It can be caused by one of many factors or a combination of factors such as tire pressure, fork height in clamps, rear shock rebound, sag height and body positioning. First things I would adjust is lowering the forks in the clamps by 3 -5 mm and increase rear shock rebound damping and see how that works.
Old 09-18-2007, 01:06 PM
RoostRM125's Avatar
Is rear shock rebound when you press down on the seat and the bike should slowly raise back to regular height? If so I've tried to make it so the rear slowly rises but it's still like a spring just spring back up really quick. Where is that clicker adjustment located just to be for sure?
Old 09-20-2007, 09:27 AM
RoostRM125's Avatar
Bump ???
Old 09-20-2007, 09:37 AM
triplendo's Avatar
Moto Enthusiast
Last Online: 03-12-2010 02:52 PM
It sounds like you need your forks rebuilt, you should have compression and rebound dampening. If your seals are shot or have dirt inside it lets the fork oil leak out and you won't have any dampening at all, in either direction. And if your getting head shake the last thing to do is put more weight on the front.
Old 09-20-2007, 05:14 PM
RoostRM125's Avatar
They are not leaking just squeek sometimes when they haven't been rode for a few days.
Old 04-28-2008, 03:42 PM
yz125#22's Avatar
Last Online: 08-07-2008 09:11 AM
my 1997 yz 125 does the exact same thing. I am kinda new to the mx world so i dont know alot about forks and stuff. i am about same height and weight. My forks do feel a little stiff but i dont know whether to adjust the compression or the reabound?
Old 04-28-2008, 08:04 PM
Last Online: 02-22-2010 12:01 PM
it sounds like your front end is too stiff. come out on the compression two clicks. also you could try slowing the rebound 1-2 clicks. make sure your sag is properly set. your pretty light for the bike so you may need lighter springs. drop the forks in the tripple clamps a couple of millimeters. reduce air pressure a couple of pounds.
Old 04-29-2008, 04:16 PM
Dell30rb's Avatar
Last Online: 05-06-2009 01:09 PM
If your fork have worn out internal (squeaking?? sounds bad dude) parts you can mess around all day long with clicker settings and never get anywhere. With bikes that old, if you have never had them rebuilt or don't know when the previous owner had them rebuilt.. chances are they need to be rebuilt.
what bmxer said is all right.. get your sag set, check your bearings (wheel bearings, steering stem bearings, linkage/swingarm bearings). If all of those things check out, then you've probably got issues. Think about the kind of pressure and constant cycling the forks endure when riding.. coupled with the fact that most people never change their fork oil (so its always dirty)... a good year or two of riding is all it takes to start wearing stuff out.
135 lbs is a little light for the springs but you arent terribly far off.. if you're getting bad headshake then chances are you've got problems somewhere
Old 04-29-2008, 04:34 PM
low430's Avatar
Last Online: 09-27-2008 10:18 PM
Great thread, I almost died twice from this what I call the bike "shaking its head" Its usually when Im Wide open and hit a succesion of bumps or puddles, the bike violently shakes far left to far right and you have to fight it hard to regain control and not go down, My 02 cr250 is doing this and it has very low hours, I had a feeling it might have something to do with suspension settings so, untill I get it fixed Im taking it easy
Old 04-29-2008, 04:37 PM
Dell30rb's Avatar
headshake is definitely dangerous, you really have no control
Old 04-29-2008, 04:55 PM
Oklahomarider's Avatar
Last Online: 07-28-2009 01:39 PM
Don't forget your shock, get it rebuilt too. If it feels like just a spring its not working properly either.
Similar Threads for: Front end bouncing around
seat bouncing honda7805cr250 2-Stroke Motorcycles - Honda 12 01-08-2008 05:57 PM
Tips on seat bouncing Sanchez #22 Motorcycle Riding Tips 16 08-17-2007 01:11 PM
seat bouncing 2000 cr250rider Motorcycle Riding Tips 5 08-23-2006 10:40 AM
Great tip on seat bouncing bates393 General Discussion 6 02-02-2005 11:34 AM
Seat Bouncing Jumps??? huffdaddy70 General Discussion 29 02-05-2004 07:11 AM
