Old 02-28-2004, 02:52 PM
kevinfries's Avatar
Last Online: 12-24-2004 10:28 AM
Question Cr 125 fork seal
I was wondering if you need any special tools to change the fork seals on a cr 125(1986). What do i have to do to change them? Any help would be apreciated, also how much do you think someone should charge to change fork seals,if i am providing them?
Old 02-28-2004, 05:12 PM
Spitfire's Avatar
Banned
Last Online: 08-10-2006 02:25 PM
Default Re: Cr 125 fork seal
If it was anything like my old bike, alls you have to do is remove the forks from the triple trees, then remove the black dustcaps, then you can just violently (haha) pry out the seals and replace them.....it's really easy, i'd do it on your own.......i called up a place around my area and they said they'd charge 50 bucks......
Old 02-28-2004, 05:21 PM
Shocknut's Avatar
Last Online: 05-01-2009 10:30 PM
My advice is this...if you don't have a manual then I would see if you can get somebody to show you how to do it the first time, that way you see just what tools you need, and hopefully learn the proper procedure. It's really not that difficult to do but watching somebody with some experience is worth their price of admission. You will likely pay the same price on the labor involved and would only be saving yourself the cost of the seals.
To change them you will need either impact gun or damper rod holding tool, a 14mm hex bit or allen wrench. You have to remove the damper rod bolt/assembly, the
Remove fork cap
remove spring
dump oil
pry up dust cover
remove seal retaining clip
remove damper rod bolt/assembly
and slide hammer the forks apart to knock seals out.
You might as well inspect your bushings, I'm sure they are toast by now. Set oil level around 110mm, use 10 wt fluid
Have fun It's a sloppy good time!
Old 02-29-2004, 01:13 PM
kevinfries's Avatar
ive got a clymers manual and the original manual for it. Im going to try to do it myself this week. Do you any messengers where it would be easier to talk? I dont understand some of that. Thanks
Old 02-29-2004, 10:05 PM
Last Online: 02-03-2009 04:21 PM
Originally posted by Spitfire
...remove the black dustcaps, then you can just violently (haha) pry out the seals and replace them.....it's really easy...
There's a clip to remove somewhere in the process. If you forget the clip, you may become very violent:
Similar Threads for: Cr 125 fork seal
2003 yz 250 fork seal MINK 2-Stroke Dirt Bikes - Yamaha 5 03-12-2008 12:31 PM
Another Leaky Fork seal - KYB jasoncarothers Dirt Bike Suspension Tuning 6 11-01-2007 10:16 PM
2003 kx 250 fork oil and fork seal service wera917 Dirt Bike Suspension Tuning 4 02-04-2007 09:26 PM
Fork seal replacement??? allstardrafter General Discussion 12 03-20-2006 08:38 AM
FORK SEAL TUTORIAL? UK VIKING General Discussion 6 01-14-2006 10:06 AM
