Old 06-21-2009, 05:16 PM
Default Can't remove inner tube (stuck oil seal ?)
I've been trying to rebuild my 99cr250 forks and can get the innner tube from the outer tube . The Oil seal seem to a stuborn mofo!!!! I just tried putting a steel rod down the the fork and beat it out even that had no succes!!
Is there a trick I don't know about here ?
I followed the factory manual to the T along with the Pivot works Video on there site .
Help!
Old 06-21-2009, 05:42 PM
Did you remove the clip just in front of the seal??
Let's hope you didn't do any damage with that steel rod.
Try heating the seal/bushing area with a hair dryer first, then just like the video, slide bang the inner & outer tubes..
The Pivot works video is for closed cartridge forks, here's a few vids for open cartridge forks..
Part 1
part 11
Old 06-21-2009, 07:22 PM
Yup- clip is off ,I tried heating it , adding more heat , Doing the slide hammer deal does'nt work as the inner tube gets stuck .
I wish it went just like the video , but Something is amiss in this fork and it did'nt .
I put an offer(ebay) on some 98 forks and and have 99 set on my watch .
Will crf450 forks will on this bike ?
Old 06-22-2009, 11:19 PM
Age is a state of Mind
Are the CR forks 47mm? If they are, the CRF forks should work fine. The biggest difference is going to be the spring rates and of course the internal valving will be a little different, but they mechanically they should be fine.
Old 06-23-2009, 09:10 AM
I got the 98 forks- better deals could be had , but not to my house by the end of the week .
Old 06-23-2009, 05:17 PM
ha ha, and I hear that. The sooner you can ride the happier you will be.
Old 07-04-2009, 06:30 AM
Last Online: 09-26-2009 02:24 AM
i have almost the same problem on my cr250 2000. but ther its the back up ring thats stuck. how can i get it loose?
Old 07-04-2009, 07:42 PM
Tdub's Avatar
Sometimes the 2 bushings will wedge themselves inside of each other and then the fun begins!
Old 07-05-2009, 09:45 AM
how do you get it out then?
Old 07-05-2009, 10:28 AM
Tdub's Avatar
Worst case scenario when I couldn't get the forks to extend or retract I had to cut the outer apart. Not a cheap fix. It has only happened to me once a long time ago before I started using heat to loosen things up first. Tdub
Old 07-05-2009, 11:41 AM
now i got the back up ring out. but not the bushes. how do i get them out with out destoying the fork?
Similar Threads for: Can't remove inner tube (stuck oil seal ?)
Shock Rebuild - Seal Head Stuck redeye12345 Dirt Bike Suspension Tuning 2 03-30-2009 07:38 PM
remove cable msf 2-Stroke Dirt Bikes - Suzuki 0 12-08-2007 10:00 AM
How to remove forks... festerovic 2-Stroke Dirt Bike Forums 3 03-06-2006 04:15 AM
Chick gets arm stuck in missile tube at AF base. 2kHondaCR500R General Discussion 3 08-21-2004 03:22 AM
