Old 06-11-2014, 01:17 PM
nldreesm's Avatar
Last Online: 05-04-2018 01:53 PM
Default Bad Free Piston Seal?
I installed gold valves in my Showa Twin Chambers from my 2005 RM250 yesterday. I have filled, and bled the inner chamber on both forks. After being compressed, the damper rods will extend quickly on their own until about 1 to 1.5 inches away from being fully extended.
I watched the video of a damper in need of a rebuild here: Leaking Showa Fork Cartridge - YouTube
My dampers extend much farther than the damper in the video. It also does not suck back into the cartridge at all.
Does anyone feel my forks are a candidate for a rebuild, or is this something I should not be worried about?
Old 06-11-2014, 02:05 PM
When the seal is bad, the rod will get drawn back into the chamber when trying to fully extend it.
Old 06-11-2014, 02:16 PM
stevo450's Avatar
Perhaps there wasn't enough oil...
Old 06-11-2014, 02:38 PM
nldreesm's Avatar
I believe I just received my answer after sending an email to JBI:
That is pretty typical of the Showa damper not to completely extend out at the way. The pressure from the pressure spring becomes less and less as the rod extends out.
To get the Showa damper to extend out 100%, when you do the final cartridge bleed by compressing the fork, leave about an inch of the rod sticking out.
Maybe keep an eye on it and let the cartridge sit over night and see if it changed at all.
JB Covington
Ride JBI Dirt bike motocross suspension parts service specs gear tools Arizona
480.269.5585
Old 06-12-2014, 08:05 AM
Randog Leader's Avatar
I had this same fear on my forks. It is completely normal for older forks to have that last inch or two move at a snail's pace. As long as they extend at the same rate of each other and that they extend fully, no matter the amount of time, you are good to go.
Old 06-12-2014, 08:17 AM
nldreesm's Avatar
That makes me feel a little better knowing someone else has had the same experience with no issues. Now I just have to hope Race Tech is spot on with their recommended valving so I don't have to tear them apart again!
Old 06-12-2014, 08:21 AM
It gets easier the more that you do it. I did both chambers twice because I thought something was wrong when they didn't come out at the same speed. I must admit that I found out the bleeding process is easily overlooked. I stroke those things a TON and even leave them overnight to be sure that there are NO bubbles left. Did you use Race Tech Ultra Slick fluid?
Old 06-12-2014, 09:51 AM
nldreesm's Avatar
I used Bel-Ray 5 wt. I figured there was a high chance that I would be dumping it so I didn't want to spend a fortune on the fluid.
Old 06-12-2014, 05:37 PM
bbrmotosports's Avatar
Rockin A class
Glad you found the answer. Just an FYI, Racetech's fluids are nothing more than re bottled Spectro fluid with a large mark up in price. In my opinion and experience on the ole shock dyno. Silkolene Pro RSF fluid is the best money can buy. It's expensive but more stable than any other fluid I have seen.
Old 06-12-2014, 05:49 PM
stevo450's Avatar
Silkolene Pro RSF
I cannot find this stuff here.....
Similar Threads for: Bad Free Piston Seal?
I installed new left side seal, but didnt use grease on the seal... 96yz250 2-Stroke Dirt Bikes - Yamaha 11 01-18-2013 09:09 PM
Snapped piston ring = where to get new? Prox piston kan1s 2-Stroke Dirt Bikes - Honda 5 10-02-2012 09:45 AM
Piston and more piston questions offroad101 2-Stroke Dirt Bike Forums 27 08-01-2008 01:10 PM
Piston ring stuck to the piston! WHY? Rocky_mx 2-Stroke Dirt Bike Forums 22 06-06-2008 03:43 PM
pinched in piston ring by the piston codfish124 2-Stroke Dirt Bikes - Honda 17 09-25-2007 07:30 AM
