Old 07-11-2006, 06:42 PM
pealage's Avatar
Last Online: 03-16-2008 02:57 PM
Default 96 or 98 yz forks
Does anyone know what the fork oil height and oil weight for a 96-98 yz 250. the rider is a beginner and weighs around 200 lbs.
Old 07-11-2006, 06:59 PM
Shocknut's Avatar
Default Re: 96 or 98 yz forks
Try 90mm oil height, springs out and fork compressed. Use a 5 or maybe even a 7 wt fluid. Try starting with your compression adjuster at 14 out and rebound at 9 out.
Old 07-12-2006, 05:33 AM
pealage's Avatar
thanks i will give that a try this weekend. the front forks seem to stick at the top of the stroke. Its not my bike any ideas besides the front wheel not being tighten right. I am going to check that also, was just curious if there is a internal problem?
Old 07-12-2006, 09:25 AM
Shocknut's Avatar
Cartridge rod could be corroded/rusty . I've seen this alot on the forks with the steel cartridge rods. They get corroded and "stick" and wear the bushing out.
Old 07-12-2006, 02:03 PM
MXtras's Avatar
Manufacturer Dude
Also - the sticking could be from the lower clamp bolts being way too tight. Even at the factory reccomended torque (12 FtLbs?) the tube's inner diameter is reduced.
I tighten my lower clamp bolts to 10FtLbs with an inch pound torque wrench after noticing some resistance in the sliders during maintenance many years ago - probably in about 96.
It's also a good idea to rotate the top tubes maybe 1/4 of a turn each time you do any fork maintenance. This allows the tubes a chance to wear evenly. It can suck to get to the bleeders most of the time but I deal with it.
And like you mentioned - make sure the tubes are straight when the axle pinch bolts are tightened. I use calipers to set mine dimensionally, but most folks aren't quite as anal about stuff like this!
Scott
Similar Threads for: 96 or 98 yz forks
Are cr125 forks the same as cr250 forks? Beans 2-Stroke Dirt Bikes - Honda 1 04-13-2009 11:09 PM
will yz 85 forks fit my yz? DUDEONAYZ125 General Discussion 0 06-15-2008 08:56 PM
Forks oldschool89 2-Stroke Dirt Bikes - Honda 0 10-22-2007 11:58 PM
kx 65 forks wardmoto Dirt Bike Suspension Tuning 4 01-30-2007 08:05 PM
WR 400 Forks? HLGuthery 393 4-Stroke Dirt Bikes - Yamaha 0 01-30-2003 07:25 AM
