Old 12-23-2007, 08:38 PM
Last Online: 12-23-2007 08:42 PM
Default 2005 yz 125 rear shock adjustment
How do make adjustments to make my rear stock stiffer? Ive been told that it can be done with a screw driver but how and where?
Old 12-27-2007, 12:00 PM
YZalltheway's Avatar
Last Online: 11-05-2009 02:25 PM
Default Re: 2005 yz 125 rear shock adjustment
First you need to set the sag properly for your weight.
Then once you have that done you can mess with the compression and rebound while your at the track.
Do a search for sag and clicker adjustment on the site and I'll be willing to bet you come up with more than a couple threads.
Old 12-29-2007, 01:20 PM
Dell30rb's Avatar
do a search here or read the manual
Old 12-29-2007, 09:27 PM
Age is a state of Mind
Last Online: 06-22-2019 02:30 PM
Doesn't the 2005 have the newer twin chamber KYB forks?
If so, the screw on the top adjusts compression, the screw on the bottom is rebound. You want both sides to be the same.
Similar Threads for: 2005 yz 125 rear shock adjustment
cr 125 rear shock 2001hondacr125 Dirt Bike Suspension Tuning 6 04-05-2008 10:58 PM
Rear shock adjustment question 95843 Dirt Bike Suspension Tuning 3 12-29-2007 09:12 PM
2005 KX250 Broken Rear Shock? jasoncarothers Dirt Bike Suspension Tuning 0 10-04-2007 10:56 PM
REAR Shock PSI? basanch73 4-Stroke Dirt Bikes - Yamaha 5 08-16-2007 08:07 PM
Rear Shock kawaboy22 General Discussion 0 07-16-2007 04:11 PM
