All Things Moto! Web Forums
Torque wrenches
This is a discussion on Torque wrenches within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; I'm in the market for a torque wrench and am curious what our fellow ATM'ers are using and how much ...
Old 01-09-2008, 03:45 PM
kjjz28's Avatar
Last Online: Yesterday 12:41 PM
Default Torque wrenches
I'm in the market for a torque wrench and am curious what our fellow ATM'ers are using and how much you roughly spent? I don't want to spend a lot of money but I'm not going to buy anything cheap. Also, I've noticed some are ft. lbs and other are in. lbs. My manual lists ft. lbs and Newton Meters. Thanks in advance!
Old 01-09-2008, 03:49 PM
pjg351's Avatar
Tie me Kangaroo down sport
Last Online: Yesterday 06:34 PM
Default Re: Torque wrenches
Iam sure mine has foot and newton meters, as we work mainly NM over here. Just make sure you get one than can cover most of the torque range on a bike, as they start quite low and go up fairly high on some bolts. (eg) 6-110nm
Old 01-09-2008, 03:52 PM
char393's Avatar
Incretacular!!
I love Harbor Freight... we have this one
and this one
Old 01-09-2008, 04:07 PM
Last Online: 10-11-2009 06:52 PM
and this one
Hey, that's where I got mine too!
Old 01-09-2008, 04:40 PM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 11-12-2009 01:21 PM
I've been using my Craftsman "clicker" for about 17 years ....still going strong
Old 01-09-2008, 04:44 PM
YZalltheway's Avatar
back up and running
Last Online: 11-05-2009 03:25 PM
Snap On makes one of the nicest ones I've ever seen.
You type in how many ft lbs or NM you want and then use it till it beeps. My cannondale mechanic has 3 of them.
The only drawback is that they are over $200.
I personally have a 3/8 drive craftsman and a 1/2 craftsman. I also have a 3/8 to 1/4 inch converter for the smaller bolts.
Old 01-09-2008, 05:38 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Yesterday 02:20 PM
I've had my Craftsman for about twice that long & it's still working just find, it's a wonder as I can be ham fisted sometimes
Old 01-09-2008, 08:53 PM
I have a batch of them. I am a tool junky. I have snap-on and some craftsman. the craftsman pro is plenty good enough for most pro's. heck I even have a torque meter though. consider an inch pound one in the future, if you look all through your manual it will call for it in a few places.
Old 01-09-2008, 09:06 PM
dhighlan's Avatar
There Can Be Only One
Last Online: 12-02-2008 10:00 AM
I just have a few Craftsman's both in Ft/lbs and in/lbs. I have never had a problem and had them calibrated couple times never off.
Old 01-09-2008, 10:06 PM
Mainjet2001's Avatar
Last Online: Today 01:06 PM
There are some pretty decent deals on EBay.
Old 01-10-2008, 12:58 AM
2fun's Avatar
Super Sonic Moderator
Just an FYI....
1 ft lb = 12 inch lbs and vice versa.
So you can use either one, but I believe the ranges are different, meaning the inch lb torque wrench probably doesn't go as high as the ft lb torque wrench will go, and vice versa. Plus the inch lb torque wrench will probably be more accurate for the smaller torque #s.
Old 01-10-2008, 01:00 AM
2fun's Avatar
Oh yeah, the cheap ones are usually not as accurate as the more expensive ones, but on the other hand, a cheap one is probably better than none!
Old 01-10-2008, 08:27 AM
The Baron's Avatar
Problematic Poster
I got a free Snap-On electronic torque wrench when I bought my YZ450. It sure was a nice piece and would vibrate and beep when you hit your torque spec and was super easy to use. But i didn't need it so I sold it for $250.
Old 01-10-2008, 08:48 AM
Originally Posted by The Baron View Post
I got a free Snap-On electronic torque wrench when I bought my YZ450. It sure was a nice piece and would vibrate and beep when you hit your torque spec and was suer easy to use. But i didn't need it so I sold it for $250.
Wow, that's a nice throw in for a bike purchase
With all the cast Al and the money invested, a torque wrench is a must. I use it for just about every bolt on the bike
Old 01-10-2008, 09:10 AM
dhighlan's Avatar
I am with you there, everything but the Plastic. Learned a few tricks from a couple Drag teams around here on where to hold the handle on 3/8 and 1/4 and it is suprising accurate (not Perfect but in a pinch nice to know)
Old 01-10-2008, 10:14 AM
chabat's Avatar
Last Online: 06-25-2009 11:06 AM
I have a craftsman inch pound clicker one. It was a little expensive. But for the small bolts it works great. I have a craftsman beam type... for large bolts. It will get you in the range, but not as accurately as a clicker.
Two more things.
1) The manual on the clicker one says it must be calibrated every so often. I never have on mine, but FYI, you are supposed to (if it says to).
2) I borrowed one before I had one, a clicker. I was working on a car and I broke a fuel line bolt (hollow bolt) and OH what a pain that was to get it extricated and goto Porsche for a new bolt. The torque wrench never did click! Point I am making is this. They can let you down, like anything else, they can fail to do what they were designed to do... So be very careful when tightening ... that if it does not "feel" right, stop tightening! before you break a bolt or strip something. This is especially true on smaller bolts.
Old 01-10-2008, 11:06 AM
The Baron's Avatar
Problematic Poster
FYI - ALWAYS turn the clicker type wrenches to zero after each use otherwise the calibration will be garbage.
Old 01-10-2008, 12:24 PM
VET393's Avatar
2007 CRF250X
Last Online: Yesterday 01:16 PM
I have a MAC clicker style in/lbs. I also have a vintage Craftsman beam style I use at the track for my axles and such.
When I got my '07 YamYZ250f last year, I got the 3/8" electric impact driver. It is a SnapOn and I use it all the time. Free with the bike!!
Old 01-10-2008, 05:42 PM
Last Online: 01-13-2008 06:03 AM
I bought this morning a torque wrench. It costed me 34 euros (50 dollars). Thats very cheap. It goes from 10 to 210 Nm. Not a high quality wrench, but it is good enough for non professional users.
Old 01-10-2008, 05:44 PM
char393's Avatar
Incretacular!!
I have the same one JohnJon... we use ours quite a bit..me likey
They did offer us the torque wrench too, but the impact made more sense for us.
Just out of curiosity, where does one have a torque wrench calibrated?
Tags
torque wrenches
Similar Threads for: Torque wrenches
Torque specs! daveythewavey19 2-Stroke Motorcycles - General Discussion 0 12-06-2006 06:21 AM
New CRF Torque Valve bates393 General Discussion 8 04-17-2006 08:48 PM
108,920 hp, 5,608,312 lb/ft torque ahighland General Discussion 10 12-31-2004 11:50 PM
the movie torque yami250fgal393 General Discussion 18 06-15-2004 11:31 AM
torque wrench dirtrider1 General Discussion 21 04-16-2004 12:31 PM
