Torque wrenchesThis is a discussion on Torque wrenches within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; I have a craftsman beam torque wrench. I think I was $30 or so. It's a cheaper one, but it ... |
#41
| I have a craftsman beam torque wrench. I think I was $30 or so. It's a cheaper one, but it works better than no torque wrench. I've used it on almost every bolt on my bike (including the top end a few months ago) and nothing has stripped or broken. It might not be 100% dead on accurate, but I guess it's close enough. It's easy to calibrate too. |
#42
| I use and old school beam style Craftsman torque wrench that was given to me as a gift by a fellow ATM'er. Not the fanciest thing out there, but it has served me well so far. |
#43
#44
| Ha ha, I can't disagree with that. I have bought plenty of crappy tools in my day, and some of them have worked well. Others not so well. Torque wrenches though I stick to a good brand. You are obviously free to use what you want. |
#45
| One more time...... Quote:
#46
| I've got a few beam types and two clickers (a Proto 150 ft. lb. & an off-brand inch lb.) but these two Snap-On dialers are my favorites.... ![]() ![]() The 5 footer is a 1000 ft. lb. and shorty is a 50 ft. lb. Personally, I won't use beams anymore and the clickers seem to go out of calibration pretty quick, even if zeroed-out every time. My Proto will now only calibrate for right-hand, can't use it on lefties anymore but it's about 30 years old or so....got my money's worth out of it. The jury's still out on the digitals, I have a hard time trusting anything digital. |
#47
| This brings up a good question, how do you calibrate a torque wrench? Do I need to take it somewhere if I want it checked? |
#48
The only calibration unit I ever saw, was in a local CPT (Chicago Pneumatic Tool) plant...they did their own calibration. It was a huge metal frame, about 6ft. tall and had a large, weighted pendulum-looking thing, hanging from an axle at the top of the frame. The wrench was applied to the pendulum and as it swung upward, a scale and pointer on the pendulum and frame indicated the actual torque. |
#49
| cool, thanks. I recently found my torque wrench had been used and left @ 80ft/lbs for a month or so, so I was a bit worried about it being messed up since it was at that torque spec for so long. It seemed to work fine as I made sure to test it on some stuff that was already torqued to spec and it clicked just like it was supposed to. In stead of sending it off, I think I'll just continue to check in periodically since I'm too cheap. |
#50
| Yeah, as long as you have a way to check it, I wouldn't sweat calibration. Unfortunately, I'm not the sole user of my torque wrenches and I've found my clickers had been left at a 100+ ft. lbs. setting, for up to several weeks at a time and on several occasions. I sent both for calibration a few times and no adjustments ever had to be made, 'til the last time...the Proto won't calibrate to the left anymore. It's now right hand only but I can't recall ever using it for a leftie, anyway. |
#51
| Thanks, that's good to know... Yeah, I can't imagine many of us run into left hand threads very often. I suppose it would be nice to have if you did need it. But the only left handers I can recall ever using are pedals on a bicycle, which I don't torque anyway |
#52
They all get calibrated once a year. |
#53
#54
| Aww man, you'll ruin it if you push the pointer back....ya' gotta' use a 2# maul. |
#55
With the maul pointy end? Last edited by Mainjet2001; 07-13-2009 at 10:00 AM. |
| Tags |
| torque wrenches |
| Torque specs! | daveythewavey19 | 2-Stroke Motorcycles - General Discussion | 0 | 12-06-2006 05:21 AM |
| New CRF Torque Valve | bates393 | General Discussion | 8 | 04-17-2006 07:48 PM |
| 108,920 hp, 5,608,312 lb/ft torque | ahighland | General Discussion | 10 | 12-31-2004 10:50 PM |
| the movie torque | yami250fgal393 | General Discussion | 18 | 06-15-2004 10:31 AM |
| torque wrench | dirtrider1 | General Discussion | 21 | 04-16-2004 11:31 AM |
