Torque wrenches
This is a discussion on Torque wrenches within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Thanks for all the input folks! One more question, I've been told a beam/pointer type is good for ft. lbs ...
Old 01-11-2008, 09:30 AM
kjjz28's Avatar
Last Online: Yesterday 12:41 PM
Default Re: Torque wrenches
One more question, I've been told a beam/pointer type is good for ft. lbs and a dial is good for in. lbs....does anyone use a pointer type for ft. lbs? Guess I'm a bit skeptical on the accuracy of those?
Old 01-11-2008, 10:09 AM
VET393's Avatar
2007 CRF250X
Last Online: Yesterday 01:16 PM
Originally Posted by char393 View Post
Just out of curiosity, where does one have a torque wrench calibrated?
I can have mine calibrated by Mac Tools.
And I use the beam/pointer type FT/LB just on my axles at riding areas.It is in my tool box I take with me when I ride.
Old 01-11-2008, 05:41 PM
I've been RM-Zedded
Last Online: Today 01:39 PM
I have a craftsman 3/8" that I love. I bought the little more expensive one that goes from 5 ft/lbs to 80 ft/lbs (I thinks it's 80), and it's been awesome. Worked for everything on my CRF -- which is why I made sure it went to 5 ft/lbs.
It was $80 at the time, which was about 3-4 years ago.
Old 01-11-2008, 06:57 PM
Mainjet2001's Avatar
Last Online: Today 01:06 PM
I have the same one JohnJon... we use ours quite a bit..me likey
They did offer us the torque wrench too, but the impact made more sense for us.
Hi gal....
You can go under Calibration Services in the yellow pages in your area and find a calibration vendor.
I work in a small 30 man aircraft assembly shop in which we use a bunch of torque wrenches. They run from .1 in/oz to 1000 ft/lbs. They are all calibrated and very in type (clicker, beam, torque watches & electronic). We have cheap ones and expensive ones and have bought a bunch off EBay.
We also have been schooled by Boeing and Parker Hannifin on the use of torque applications.
Having said that don't assume the cheap ones are less accurate. All the ones we bought off EBay only 1 clicker was bad. Yes, maybe we were lucky...
The schools will tell you that the beam wrench is the most accurate if you require dead accuracy. Does not mean the clickers are not accurate and I use them a lot on aircraft parts.
There is a lot of info out there if you Google Torque wrenches and calibration.
Old 01-11-2008, 11:52 PM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 10-14-2009 10:24 PM
Originally Posted by Big Maico 393 View Post
I've had my Craftsman for about twice that long & it's still working just find, it's a wonder as I can be ham fisted sometimes
That thing is so old its the pointer bar that points at the number instead of a clicker type isn't H?
Old 01-12-2008, 08:09 AM
Dane....you told me Howard is a "clicker".
Old 01-12-2008, 04:59 PM
2fun's Avatar
Super Sonic Moderator
Lots of excellent info here!!
I would give it a vote for the knowledge base forums when it has run its course!
Old 01-12-2008, 05:03 PM
2fun's Avatar
Originally Posted by The Baron View Post
FYI - ALWAYS turn the clicker type wrenches to zero after each use otherwise the calibration will be garbage.
Good to know, but why exactly is that?
Old 01-12-2008, 05:49 PM
2fun's Avatar
I jus read this on a another site on a google search. Sounds interesting.
"I check my torque wrench by putting the square drive in a vise, extending the arm out horizontally, and pushing down precisely 1 foot from the center of the square drive while standing on a bathroom scale. With the wrench set to 60 ft-lb, I should be 60 lb lighter when the wrench clicks.
I'm sure it looks odd, but it works."
I guess you could try this if you have an accurate scale and no money to spend on calibration??
For that matter, I guess you could hook up one of those "pull" fish scales??
Old 01-12-2008, 06:08 PM
2fun's Avatar
Here is a link to another good article on the subject!!
Old 02-05-2009, 01:23 PM
04whyzee's Avatar
I need a truck
Last Online: 02-05-2009 01:42 PM
The reason for turning your torque wrench dial back to 0 is that it releases the tension on the spring inside of the wrench. Keeping tension on the parts in the wrench just causes the little springs and such that make it work wear out quicker!
Old 03-19-2009, 08:30 AM
liftman's Avatar
Last Online: 03-22-2009 10:50 AM
I dont know why but the place we get our torque wrenches calibrated at work tell us to always reset to 0 when not using. We use several sizes of the clicker kind and all have worked well for me.
Old 03-28-2009, 10:08 AM
Last Online: 11-04-2009 09:03 PM
snap on here
Old 04-01-2009, 07:16 PM
Dan151's Avatar
Last Online: 09-26-2009 11:02 PM
i just picked up a Husky torque wrench at Homedepot, works great and a fair price too
Old 06-14-2009, 11:18 PM
Last Online: 06-16-2009 12:15 PM
I bought mine at harbor freight and I have always properly unloaded it after use and its still an inaccurite POS! ive broken 2 bolts since i bought it...
i broke one tonight while putting the clutch back in my CR125...no more riding till i can take it to the shop and have them pull the basket since i dont have the tool to take it out...
im about to throw the thing in the trash and go to sears tomorrow and buy a digital craftsman...(what i should have done in the first place)
Old 06-15-2009, 04:21 PM
What should the torque be and what was the reading you applied to the bolt (off the torque wrench?
Old 06-18-2009, 08:57 AM
donnie's Avatar
Last Online: 11-01-2009 07:19 AM
Huskey is a nice torque wrench. It's not a arm and a leg and it repeats. Buy it and have it tested on a snap-on truck if you can. It your in the Torrance area I have a torque wrench checker at my shop.
Thanks Donnie
Old 06-25-2009, 07:24 PM
Last Online: 07-24-2009 09:57 PM
I have a built in torque wrench. It's in my head, it has 2 settings. "Loose", and "tight". Never had a screw, bolt, or nut come loose on me.
Old 06-25-2009, 08:34 PM
2001hondacr125's Avatar
Last Online: 11-05-2009 05:45 PM
i highley discourge anyone from buying cheap torque wrenches because they ARE junk, they r very inaccurate my dad works on cars and told me that what ever i done not to buy a cheap torque wrench. Hes got a snap-on and craftsman one which both work great
Old 06-26-2009, 03:32 PM
I've been RM-Zedded
When it comes to tools, I think the adage "You get what you pay for" applies. I know it has for me.
Tags
torque wrenches
Similar Threads for: Torque wrenches
Torque specs! daveythewavey19 2-Stroke Motorcycles - General Discussion 0 12-06-2006 06:21 AM
New CRF Torque Valve bates393 General Discussion 8 04-17-2006 08:48 PM
108,920 hp, 5,608,312 lb/ft torque ahighland General Discussion 10 12-31-2004 11:50 PM
the movie torque yami250fgal393 General Discussion 18 06-15-2004 11:31 AM
torque wrench dirtrider1 General Discussion 21 04-16-2004 12:31 PM
