pipe dent repair
This is a discussion on pipe dent repair within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; here we go here's how to repair a dented pipe. This will actually be in several posts because I will ...
Old 02-14-2003, 08:09 PM
Yardpro393's Avatar
393 race team
Default pipe dent repair
This will actually be in several posts because I will post pics of the "tools" that i made. I can't host them so i have to do them one at a time.
1. remove from pipe
2. clean pipe. especially the inside of both ends. use contact cleaner for the inside of the ends. You just need to get rid of the oily spooge
3. remove o-rings from large end.
4. I mount the pipe in a vise using the first tab that the pipe has
5. that mounts it to the bike.
6. using a 1/2' or 3/8' expansion plug ( size depends on bike), I plug the silencer end of the pipe. wrap safter wire over the top of the plug and secure to the rear mounting tab on the pipe.
----an expansion plug can be bought from any hardware store. It it used to temporarly plug pipes. it is a clyindrical piece of rubber with a threaded bolt through the middle and washers on the top and bottom. As you tighten the nut the rubber squeezes outward, creating a tight fit.-------
7. use a larger plug for the large end, again using saftey wire over both sides of the top and secure to the spring mounts.
---- this plug has to be modified. I switch the stock carrage bolt with a longer one that os a standard size ( 7/16 X20X4). drill the center of the bolt to create an air passage. put bolt through plug as the origional was. screw on wingnut and snug up. on the threaded end of the carraige bolt adapt to accept a male quick connect compressor fitting. see pic below.
Old 02-28-2003, 08:54 PM
Dell30rb's Avatar
Default Re: pipe dent repair
Keep em comin, this is great stuff!
Old 12-26-2003, 07:47 PM
Blitz393's Avatar
^^Get High^^
Last Online: 10-16-2009 07:12 AM
NEXT, you fill the pipe with about 15-20 pounds per square inch of compressed air. (15-20 psi) then, take a propane torch and heat up the dent. once the area gets soft enough, it will pop out to normal position from the pressure inside the pipe.
correct?
Rob
Old 06-07-2006, 12:31 PM
quadfather03's Avatar
Last Online: 07-26-2009 01:06 AM
Incorrect fill the pipe with 80 lbs per square inch, heat the area to a decent temp and then drop a piece of ice on it and the metal will contract. The metal stretches when it is dented so you need to contract to make it smooth again.
Old 08-11-2006, 12:26 PM
MXtras's Avatar
Manufacturer
I just have to comment here. I am not bashing - I simply feel obligated to speak up here.
As a mechanical engineer at one of the world’s largest companies, I have taken numerous metallurgy courses and I deal with material properties frequently. Anyone with any amount of knowledge of metals knows that heat and then rapid cooling hardens steel. Even low carbon steels - like that used for making pipes - will be affected. Combine a brittle surface with 80 PSI internally and you are creating a very unsafe condition created by a procedure that should not be recommended on a public forum. You are also creating a pipe that is substantially more likely to fail from fracturing; this is not an opinion, it is metallurgy.
I would advise anyone against trying your suggestion with 80 PSI.
You may fill your pipes to be repaired with 80 PSI and then heat them up and shrink them with ice, but to suggest this on a public forum is asking for trouble and is not responsible as it is not exactly a very safe approach. I am sure it has worked numerous times for you without failure but I would never attempt this and I have straightened my share of pipes over the last 30 years.
Granted - when riding, the pipe can be extremely hot and then may be quenched when you go through water, but the temperature extremes are far less than heating with a torch and then quenching with ice.
A rupture at even 15 PSI can cause a severe eye injury, so make sure you wear all the appropriate protection - including heavy gloves, long sleeves, safety glasses and a face shield and wear a heavy leather apron to protect your stomach. Safety wire all of your plugs and fittings and check their condition periodically.
For those wanting to straighten a pipe, use air and heat and stay away from the ice. Use a propane torch - not oxy/acet torch. Propane will not create enough heat to melt the steel, where the O/A torch obviously can and the propane torch will not oxidize the pipe like the O/A torch will.
If 45 PSI will not push the dent out, slow down and take your time and apply the heat to a larger area. You might have to push the areas around the dent out farther than needed and then lightly tap the shape back in place with a wooden or soft faced mallet. 30-35 PSI and a propane torch will remove most average dents in OEM pipes unless they are heavily creased or folded. Some of the heavier pipes - like PC Titanium series - typically take a little more pressure - around 35- 45 PSI. If you need more than 40 or 45 PSI, you might want to re-consider the repair; at least that has been my experience.
If the pipe is really bent up and the heat/air doesn’t do it, you might have to cut it open to form it back into shape and then weld it back up or send it out to someone who does pipes and let them deal with it – they don’t charge that much and it’s a lot cheaper than a trip to the ER. Of the pipes I have repaired, I have had to cut open maybe 25% of them, but I get some pretty mangled up pipes from local dealers - many look to be beyond repair.
That’s my story and I am sticking to it. Flame away.
Scott
Old 08-12-2006, 06:48 AM
super rat's Avatar
Last Online: 08-14-2006 09:30 PM
Makes good sense, THANKS
Old 08-12-2006, 05:49 PM
I happen to be an experienced welder fabricator and the metal used in the pro circuit platinum pipes will handle this technique time and time again. Your point however is an issue with factory pipes that i have yet to do we all run aftermaket around here. I agree with the propane torch as well that is what I use. I have never had a dent budge until i hit 80 psi then it slowly starts coming out after 80 percent of the dent is out then i add the ice for the last little nick that is left.
Old 10-18-2006, 12:31 AM
bigtree686's Avatar
Last Online: 09-28-2009 05:40 PM
i wonder if we could send this myth to myth busters?
Old 10-18-2006, 09:36 AM
MONSTER450's Avatar
Stewie Tuned
Last Online: 01-18-2009 01:39 AM
i happen to be a diesel mechanic and i deal with metal parts in motors all the time and i think fixing dented pipes is a good idea.
Old 07-25-2007, 12:20 AM
Last Online: 11-29-2008 11:28 PM
i have no proof and this is more a question than a statement but wit a perfectly normal temperature bent pipe can you just hold a peice of dry ice on the dent and it will invert?
Old 10-14-2008, 06:16 PM
Last Online: 11-09-2008 10:55 PM
Default Motocrosspiperepair.com
I fix dented and bent pipes all day long. I just pump up the pipe heat the dents which come out easily. High pressures and high temperatures are dangerous for sure. I've never heard of putting ice on a dent under pressure and heat. Forget Mythbusters, I will try it and get back to you.
Old 10-17-2008, 09:57 PM
Last Online: 02-15-2009 01:49 PM
slide hammer works.
or drill a hole in the middle of the dent and stick something like a crow bar in there to pop the dent back
Old 11-05-2008, 02:05 PM
Last Online: 09-28-2009 12:14 AM
With ANY air pressure the biggest safety issue is the plugs. The safety wire securing the plugs is paramount. If you had 45 or 80 psi and a plug came out headed in your direction it could very possibly be fatal.
Old 11-05-2008, 05:19 PM
2004CR250's Avatar
Last Online: 11-05-2009 12:54 PM
nothing against doing it yourself, but when i get mine repaired, I am just going to pay $50 and have this guy do it:
I am not endorsing that company though, because I have never sent one to them yet. I just have a feeling that there are people out there looking for an expert who can do it for them.
Old 11-05-2008, 06:26 PM
racerfty's Avatar
premix sniffer
Last Online: 10-11-2009 10:41 AM
i remember reading, years ago i think it was dirt rider mag, about a test they did with dented pipes, where some of the dents had better dyno runs then no dented pipes. If i remember correctly the dents were what were seen durring rididng, with no fabricated dents. but as in physics, nothing is free, to gain, is to loose something else.
Old 12-03-2008, 11:02 AM
Last Online: 12-03-2008 11:02 AM
Default Forget About It
I've been through all that stuff, don't waste my time anymore. I have two FMF pipes for my KTM. When I smash one, I send it to a guy who is amazing, he only charges me $20. While he fixes one pipe I put the spare pipe on and keep riding. Most of the time I end up with two good pipes on hand but when one gets smashed it goes to Motocrosspiperepair com, I never have any down time using this method.
Similar Threads for: pipe dent repair
Anyone used Pacific Crest Pipe Repair? Pipe repair done right! The Baron General Discussion 3 07-30-2007 05:33 PM
Exhaust Pipe Dent Removal casa_60 2-Stroke Motorcycles - General Discussion 12 07-06-2007 05:07 PM
Getting a big dent out of pipe. redrider8 General Discussion 8 07-26-2005 06:52 AM
Big Dent in Pipe! AaronRider 4-Stroke Motorcycles - Honda 9 07-09-2004 01:23 PM
pipe dent removal- calling YP Blitz393 2-Stroke Motorcycles - General Discussion 17 04-17-2004 01:01 PM
