How To: Installing GripsThis is a discussion on How To: Installing Grips within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; DBD thats what I use, works for us also.... |
| | LinkBack (1) | Thread Tools |
#61
| DBD thats what I use, works for us also. |
#62
| Just wanted to add... On my throttle, I used a can of Prestone brake cleaner to get the old grip glue off (smells like finger nail polish remover to me). I also want to add -- on my new Tag T2 bars, I put some Renthal grip glue on and let it get tacky for a short couple seconds, then put a bit more on and slide the grips on. They have not moved at all since glued. Regards, John |
#63
| Even with the glue, I safety wire my grips. Just ask stickboy what happens when your grips come off!! |
#64
| Vet is right. Safety wire them on. I had one come off too about a year ago and it's not pretty.......imagine landing a double one handed.....OUCH!! |
#65
| I safety wire my grips as well. I haven't had any problems with them falling off yet. |
#66
| Imagine landing with both grips in your hands. Stickboy needs to inform you about his little trick |
#67
| another good way is gettin some paint thinner and pooring it in the grip and slide it on, its really easy and once it dries it wont budge, |
#68
| You can take off grips without tearing them up. I use an aircompressor and just blow the grips off. I use the same thing to put them on. |
#69
| I just tried using "Gorilla Glue" to put my grips on. dampen the bars very slightly, thin coat of the Gorilla stuff, and not one budge (so far). |
#70
| I use gas Don't yell...I don't know any better. |
#71
I have no idea how you are going to be able to change those grips with out a grinder! But then again, you may never have to change them. I sure hope thats the case. Hair spray--works great! I was able to ride in less than 1 hour after new grips. grip glue-- don't use it that stuff was never set days after grips were put on! AIR COMPRESSORI KNEW THERE HAD TO BE A WAY TO GET THEM OFF WITH OUT CUTTING THEM UP! |
#72
| take a small ball pean hammer and tap the clipped ends into the soft of the grips so the"pokey" ends are facing the actual bar not your palm |
#73
| I used to use Carb Cleaner also. Seems to work the same as hairspray. The chemical in it works just like a glue when it hits the rubber and "joins" it to the bars. I also use zip ties. About 4 do it for me. Just make sure the "heads" are where they will not bother your fingers. Near the front bottom works good that way they will fall between the center knuckles. They act like an extra grip on muddy or extra wet days to. |
#74
| pro taper grip glue is awesome:-) only a few min. and there on there real good lol |
#75
| .... hmmm im gonna be changing my grips when i get a new bike. How does this safety wire work? Do i just get a pair of pliers and wire, then wrap it around and twist it to tighten it on, then cut the end off? |
#76
| SAFTEY WIREEEE you need savety wire pliers to twist the ends together, then cut the excess with about 1/8 of an inch left and fold i over (i usually push the end up into the grip with the end of the pliers) the thicker the grip, the easier to hide the sharp end |
#77
| Saftey wire is the only way to go. A true life saver. |
#78
| we use rave 4 or 5 hairspray but u have to put the grip on quick after u spray it and then saftry wire them somtimes |
#79
| i always clean the handle bars off and grab the spray paint clear coat spray it in them and when it dries they dont budge |
#80
| I know this subject is a little old, but I don't have installing problems any longer with Ruffian clamp grips that I picked up at Alba Motorsports in Poway, CA last month. They went on in about 5 minutes. The kit gave the left grip with clamps, two sets of bar ends, throttle tube and grip and allen wrenches all for $23. I've had two spills with them on since and they didn't budge or jam up the throttle tube or anything. I've definately been sold on them and will never glue or safety wire grips again. |
| Tags |
| how to, install grips |
| LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-15/how-installing-grips-5729/ | ||||
| Posted By | For | Type | Date | |
| How-To Install Grips - Details - | This thread | Refback | 09-09-2008 01:00 AM | |
| Grips | any sunday | General Discussion | 5 | 08-11-2007 09:33 AM |
| Grips for a 50? | Woody_393 | Mini Motorcycle Riders | 20 | 12-04-2004 11:00 PM |
| What kind of grips? | Doom Crew | 4-Stroke Motorcycles - General Discussion | 19 | 06-13-2004 12:53 PM |
| Renthal Grips | Mr.Boof | General Discussion | 14 | 06-02-2004 09:47 PM |
| Installing New Hand Grips? | hevnsnt | General Discussion | 28 | 10-13-2003 03:23 AM |
